I want to know how anyone got this peice of sh it header on..was there special header bolts that were needed..also what about the gasket for the header to the head portion..
considering that a coup;e of the primarys completley blocks a bolt from going into the head theres gotta be another way..please help
Built&Boosted moar
Which header?
-M
It's not a crap header, you just need to figure out how to install it.
The flange uses a standard exhaust manifold gasket, the nut under the primary has to be slid on before the flange is completely mated to the head, so when its on at an angle, slip the nut between the primary and the stud coming out of the head before you push it all the way against the head.
Also get a good ratchet wrench, it will make the job 10x easier.
For the gaskets on the second flange where the downpipe mates, just take the bottom section to Autozone or parts place of your choice and match up some paper/metal gaskets until you find ones that fit, if you need to clip the inside of the gaskets where they touch so the fit right, make sure they have the crush ring in the center of the gasket, if they dont have that they will burn out and youll get an exhaust leak. Also go get some decent grade 8 bolts for that second flange and torque the @!#$ out of it.
It also helps if you take a sanding block and block the flanges on both downpipe and bottom of header to make sure they are completely flat, it will ensure you get a good seal and no leaks.
its not called rk crappy for a bad reason , their stuff is crap
its the 4-2-1 header..we have tried that method and it still will not seal getting leak on the #2 primary , its difficult to describe what the problem is but the studs will not cut it we are going to have to use bolts..
Built&Boosted moar
I have the RK header, and It installed fine... No leaks or anything of the sort...Fuel lines a little close though.
Jason Radtke wrote:I have the RK header, and It installed fine... No leaks or anything of the sort...Fuel lines a little close though.
the 4-2-1 header..whats the deal on it mang??? How was it soo easy for you, details details!!!lol
Thanks
Built&Boosted moar
so you used all the factory studs for the header along with the stock gasket???
Built&Boosted moar
Yep. And It all worked out fine.
Matt Gorman wrote:so you used all the factory studs for the header along with the stock gasket???
i didn't i used bolts i bought at a local hardware store (home depot)
even still couldn't get all the bolts in.. but it gets the job done
well i did some research and came up with a solution..it seems to me that the ls1's share the same 8mmX1.25 bolt..so i bought the reduced header bolts and there guaranteed to work with the limited space that these headers accommodate...so i hope that we all helped eachother out here!!!LOL
Built&Boosted moar
I cant understand why you guys needed different bolts? Any pics?
the mato I live by...... "Be smarter then what your working with"
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
or beat it with a hammer
Built&Boosted moar
EXACTLY!!! whats up buddy..you dont call any more^^^^^whats up mike
Built&Boosted moar
EXACTLY!!! whats up buddy..you dont call any more^^^^^whats up mark
Built&Boosted moar
