i had a leaking injector so i changed the o ring on it put it back in now the car wont start?
thought maybe is fluuded so i took all the plugs out un hooked the fuel injectors wiring
roled the engine over a few times, put back togetther and still wont start worked fine before just had a bad fuel smell
doest anybody have any ideas of what might of happened?
could my fuel pump go that fast?
like i said it worked fine before
replaced the plugs
wires
checked all connections
still nothing ???????
What engine and what year do you have?
see if your blinker fluid is low first
jk
its a 95 with a 2.2 im towing it to the shop today to do a fuel pressure test and i will go from there, i will let you guys know what i find.
well i got it at the shop today,and dont know how to do a pressure test to this car ,its different then most.
but i did take off the cold air intake and and it would keep running when i spayed air cleaner in the trottle body
so im putting a fuel pump on tomarrow
but when i turn the key you can here the pump humming????? did this ever happen to anyone before????
please let me know, i think after i get this running im going to put a 2.2 eco in my baby, what do you guys think?
i found a smshed one wit only 40k whoooo hoooooo!
that humming noise is the fuel pump priming itself... sounds like you forgot to put stuff back together double check all ur vaccuum hoses and such........
i'm having the same problem it's going to the shop today i'll let you know if they say it's my fuel pump b/c it also primes the system
replaced the fuel pump ,works fine now
