about how much HP am i looking at in one of these and were can i get it done for under 150? what else do i need to replace? valves? valve springs? rocker arms?
depends on how much lift you are going to run and how much duration to determine what springs to use. Id get some magnum rockers from crane and get a cam regrind and keep it under 470. lift. that way you can buy new stocker springs
good luck finding someone who will grind them for under 150.... it seems like you talk the talk but cant quite seem to walk the walk.
i found place that does it for 130 but i gotta send it in so i dunno how much shipping would be
OHV CAV wrote:depends on how much lift you are going to run and how much duration to determine what springs to use. Id get some magnum rockers from crane and get a cam regrind and keep it under 470. lift. that way you can buy new stocker springs
Comp makes the Magnums, not Crane
Check out the rocker thread for everything you need to know in that category.
Crane was about 175 with shipping included.
fortune cookie say:
wow.... thx notec i have a brain hiccup once in awhile lol
