Softer Motor Mount Q's - Performance Forum
Wednesday, July 04, 2007 7:06 AM
The car is a 97 Sunfire 2.2l. I don't own the car anymore so I would like to keep the cost down if possible. It currently has the RKSport upper insert and lower dogbone and it also has a full exhaust. The vibrations are really getting to the driver. I was wondering if I could just put the mounts back to stock or would I have problems with exhaust leaks. If so is there softer ones that are made to go in. Where to get them would be helpful.
Re: Softer Motor Mount Q's
Wednesday, July 04, 2007 7:26 AM
Turbo tech racing
Wednesday, July 04, 2007 7:34 AM
Grumpy McGrumpster(BIGGSZ24) wrote:Turbo tech racing
mounts are too hard so get harder mounts??????
yea you can put stock mounts back in, should be fine assuming you have a proper flexjoint
Wednesday, July 04, 2007 7:59 AM
no,their mounts have less vibes than what he already has in their.Aluminum vs. urethane hmmmm... downgrade and lose performance or upgrade and lose some vibes.
Edited 1 time(s). Last edited Wednesday, July 04, 2007 8:04 AM
Wednesday, July 04, 2007 11:35 AM
The Turbo tech dogbone is on the expensive side, but DOES transmit less vibration from the engine to the chassis, and its just as good a mount otherwise as the RKsport/Prothane unit. Plus it looks alot better, being machined aluminum. The upper mount removed BTW, would make the vibes alot less noticeable, and with the lower dogbone you'll still have SOME of the benefits of stiffer mounts.
Wednesday, July 04, 2007 11:46 AM
put the stockers back in as long as u have the stock or something good header flexpipe.
