1.6 rockers - Performance Forum
1.6 rockers
Tuesday, July 17, 2007 8:10 PM
Do you have to change the push rods? Or any thing else for that matter? It seems to be to easy to just change the rockers. Does it make more power?
Re: 1.6 rockers
Wednesday, July 18, 2007 3:20 PM
On the '97 & older 2.2Ls, you'll need to either use the Comp Cams Magnum Roller Tip Rocker Arms for the 2.8L V6, or you'll need to replace the stock studs with a 10mm base, 3/8" top studs from ARP or Crane Cams. Both of these methods will require you grind approximately 1/8" from the guide plates groves, closest to the stud. Depending upon the stud, nut(Poly-Lock), and/or rocker arm combo, some grinding of the valve cover and/or V.C. breather baffle will be required.
On the '98+ 2200s A change of studs is required and grinding of the V.C. is required for clearance.
For more info, read 2.2/2200 OHV Rocker Arm List
