Hi jbo, I've searched and was not able to succesfully figure out which wire the tach signal is on the eco so I can run it with my zeitronix unit.
I'm talking about the one that comes off the coil packs..
Thanks!
the pink one i believe, thats the one used for the tach reading on the dyno i know
The one, the only, ME.
2465 lbs without me
141 hp @ 6300 (ran out of rpms)
123 ft lbs @ 5200
running lean stock ECU
go to the dealership and ask the service dept for a pin out of the ecu wire harness with wire descriptions and that will tell you which wire goes to what, the wire color and its pin number.
many changes in the making
my favorite part about doing bodywork,.......... bondo bugers
Tachometer white or orange ICM
its on the plug closest to the firewall. test it with a meter
