Anyone using a oil cooler? - Performance Forum
Sunday, August 12, 2007 12:04 PM
do you notice lower engine temps or what did you notice from having it installed?
Re: Anyone using a oil cooler?
Sunday, August 12, 2007 12:08 PM
If you are refering to the engine one, it is to keep the oil cooler and from breaking down as fast. You might have noticed the bolt on kit we sell @ www.TurboTechRacing.com which many purcahse.
-Aaron
Sunday, August 12, 2007 12:56 PM
I recommend it. I noticed about a 20 degree drop (easily noticed seeing as my engine runs really hot).
_________________________
Sunday, August 12, 2007 4:47 PM
aaron ive seen your kits..too bad none of them will fit my quad i have been looking at using one off an LT1 since the threads are the same..can you(or anyone) suggest a good fitting size for the cooler? AN-6 ? -8? thanks guys
Sunday, August 12, 2007 5:14 PM
Aaron, I've got an LN2, so would your company have a kit with an adaptor for my app?
Go beyond the "bolt-on".
Sunday, August 12, 2007 5:57 PM
I don't have my oil cooler installed yet, but I have -10an fittings for it
Jason
99 Z24 Supercharged
157hp/171tq - NA
Sunday, August 12, 2007 7:48 PM
the fittings on my sandwich adapter are 1/2 inch (-8) if im not mistaken clamp style fittings..so i ASSUME -8 or larger would be right..i got one cheap but it came with -6 so i would rather get another....anyone need a cooler?? lol
Sunday, August 12, 2007 8:36 PM
anyone make one for the ecotec with its screwy setup yet??
many changes in the making
my favorite part about doing bodywork,.......... bondo bugers
Sunday, August 12, 2007 8:48 PM
i dont think anyone makes an oil cooler for engines without screw on type oil filters
Monday, August 13, 2007 9:18 AM
i had one on my 2200, i didnt really notice any difference but i had all factory gauges too... i would put one on especially if u run the car hard. and only mobil 1 synthetic is what i used...
2001 Ford F250 Superduty
7.3L PowerStroke Diesel
5" Turbo-Back Exhaust
XCal-2 With Tadds Tunes
Water/Methanol Injection
aFe Stage 2 Intake
Full Set of AutoMeter Gauges.
Monday, August 13, 2007 9:45 AM
so no one makes a direct bolt on for the ECO?
Monday, August 13, 2007 12:34 PM
i saw an adapter for the ecotec that i think would work, but its made for the machines that they use to flush the oil system, so im not sure how it would stand up under hard driving, but it does screw in and have 2 fittings on it so it looks like it would work.
Monday, August 13, 2007 1:31 PM
Nickelin Dimer wrote:Aaron, I've got an LN2, so would your company have a kit with an adaptor for my app?
Yes please see www.TurboTechRacing.com
-Aaron
Monday, August 13, 2007 1:32 PM
scott (section8cav) wrote:aaron ive seen your kits..too bad none of them will fit my quad i have been looking at using one off an LT1 since the threads are the same..can you(or anyone) suggest a good fitting size for the cooler? AN-6 ? -8? thanks guys
I would think the one for the 2.4L would fit... As long as the 2.3L and the 2.4L use the same oil filter it will work...
-Aaron
Monday, August 13, 2007 1:33 PM
Chris DeNisco wrote:so no one makes a direct bolt on for the ECO?
It is much harder on the eco as it has an internal cased oil filter, unlike the LN2 and the LD9 which have the more "normal" oil filter.
-Aaron
Monday, August 13, 2007 2:05 PM
thats the thing..the 2.4 uses a delco pf46 and the 2.3 uses a pf47, OR a pf52 which is what the LT1 uses which is why i use the 52 cus its a bigger filter, allows me to utilize more oil and a larger filter..so i ordered a LT1 sandwich adaptor but im still looking for a good cooler
Monday, August 13, 2007 2:10 PM
If you have a Perma cool part number, let us know via email Aaron@turbotechracing.com and i can get you a price.
-Aaron
Monday, August 13, 2007 6:16 PM
Scott,
What sandwich adapter did you order and does it have an internal thermostat??? Earl's makes one, but a friend of mine couldn't get his to fit. I have the oil cooler and -10an lines, just need the adapter
Jason
99 Z24 Supercharged
157hp/171tq - NA
Monday, August 13, 2007 6:30 PM
Actually the LS1 and the LD9 use the same oil filter so any oil cooler kit for an LS1 should fit the LD9 and if the LGO uses the same filter as an LT1 then any oil cooler kit for an LT1 should work on the Quad4.
2000 Z24 5spd header & catback for now.
Monday, August 13, 2007 7:16 PM
It all comes down to the thread size, and the diameter of the sealing O-ring; if they are the same I see no reason why it would not work.
-Aaron
Monday, August 13, 2007 8:42 PM
Scott,
yes it has an internal tstate..but i dont know what temp its set at ..i know it screws onto my quad just right..and i know the ld9 filter wont fit my quad..i got my adapter on ebay...it has to be the LT1 not the LS1..just look up LT1 oil cooler and youll see them..there arnt many..mine came with clamp style -8 (1/2") fittings..so i just need a good cooler to hook up to it
Tuesday, August 14, 2007 1:40 AM
I would totally go with getting the oil cooler you cant lose with it...i have oil cooler and installed two twelve inch aftermarked fans, the whole setup keeps my engine cooler then ever before its great the needle never moves from regular running position.
