H.O. manifold and a 75mm vette TB - Performance Forum
Friday, August 24, 2007 12:16 PM
Would an H.O. manifold with a 75mm corvette TB work on a stock 2.4?
Would it be a waste of time or would there be a difference?
Re: H.O. manifold and a 75mm vette TB
Friday, August 24, 2007 12:23 PM
do you have any other mods done to the car?
if not it will decrease performance.TB is too big.
Friday, August 24, 2007 12:46 PM
Ok thanks. I'll save that for my other engine then
Friday, August 24, 2007 3:15 PM
The ho manifold is a good mod, but 75mm is way too big for a stock ld9. Just pick up a stock 2.3 tb as well since you can get them realy cheap, they are 56mm. Or you could have a shop or somewhere bore your stocker out to like 58mm and have a new plate made.
Saturday, August 25, 2007 8:28 AM
Ok, thanks alot
Saturday, August 25, 2007 8:41 AM
for the 75mm you will need an adapter plate made up (talk to spyhunter as he has something similiar done)
you can pick up a ho manifold with throttle body for around $50-75 cdn around here
Saturday, August 25, 2007 12:10 PM
I had an ebay company that cuts aluminum do my adapter plate in 1" thick aluminum... I just gave them this, and it came out really nice:
...I drilled the 3 bolt holes myself, though
Edit: I don't know if the vette TB is the same, but the adapter plate is for a 75mm Northstar TB
Edited 1 time(s). Last edited Saturday, August 25, 2007 12:11 PM
"Youth in Asia"...I don't see anything wrong with that.
