Lager filter for 2.4 Heres your number - Performance Forum
Monday, August 27, 2007 12:56 PM
well i looked and found a bigger filter that will fit its about an inch longer it would be a 1522 nappa gold or a 211522 pro select thought i would let every one know
<img src="http://img46.imageshack.us/img46/227/cave10wf.gif" />
Re: Lager filter for 2.4 Heres your number
Monday, August 27, 2007 1:17 PM
Thanks for the info.
Monday, August 27, 2007 2:50 PM
Delco PF59 is what I've been using for years...
14.330 @ 96.37mph
Monday, August 27, 2007 3:56 PM
i stick w/ the stock PF46, seems to do the job just fine. nice find though.
Tuesday, August 28, 2007 10:20 AM
more oil compacity = better cooling for one thing and im sure hoving a half a quart more wone hurt any thing
Tuesday, August 28, 2007 3:24 PM
The difference in cooling with the slightly larger filter is rather negligible, and really has no bearing on how much oil you put into your crankcase. I prefer to use it for the little bit of extra filtration it provides.
14.330 @ 96.37mph
Wednesday, August 29, 2007 7:51 AM
that too i just for got to put that down there is absoutly no harm in using it why not though bigger is better lol right
Wednesday, August 29, 2007 10:09 AM
i posted this up like 2 years ago....
the part numbers i gave were for Champ filters, but they cross reference completely to the Delco's
here is the recap.
(MOTOR)--------------(CHAMP FILTER)
2.4LD9-------------------PH44 (OE)
2.4LD9-------------------PH59 (Larger)
2.2LN2-------------------PH47 (OE)
2.2LN2-------------------PH51A(Larger)
2.2ECO------------------P3244 (cartrdige filter, sorry your stuck with this one)
1997 RedR - ZedR
Wednesday, August 29, 2007 3:37 PM
PF44 is now 46
Wednesday, August 29, 2007 4:22 PM
im glad this subject has arised, my question is what is the best oil filter to use with the Quad oil pump swap on the LD9 with the modified oil pan? Also how many liters shoud i add now?
GMR has got nothing on this
Monday, September 10, 2007 6:45 AM
well with the deeper pan and the bigger filter i hold 6 qts
Monday, September 10, 2007 12:12 PM
PF44/PF59 both got replaced by the PF46. the PF61 is the same thred and size (longer) BUT there is no anti drain back valve...
Chris
'02 Z-24 Supercharged
Monday, September 10, 2007 11:53 PM
I'm rockin' an 8A on my car, which is quite a bit larger than even the biggest one I've seen listed in the above posts (which would be the 59 and 51A). The PH8A filter is typically found on Ford vehicles, most notably all older full-sized Ford trucks and nearly every Explorer (Ford has since moved to an 820).
Saturday, September 29, 2007 6:44 PM
Taetsch Z-24 wrote:PF44/PF59 both got replaced by the PF46. the PF61 is the same thred and size (longer) BUT there is no anti drain back valve...
Chris
any big issue with not having the anti drainback valve?
Saturday, September 29, 2007 6:55 PM
I was going to ask this too, kinda strange that someone already did..
I wan't to install a bigger filter too, but all I can get around here is Fram for the most part.. Anyone have the fram# for the oversized ones.
Saturday, September 29, 2007 7:49 PM
Weebel wrote:I was going to ask this too, kinda strange that someone already did..
Check with your local auto parts stores they should be able to cross refrence it for you.
Saturday, September 29, 2007 11:49 PM
any autoparts store should be able to cross reference the filters i labled above.
that 8a is a mighty large one. same relief pressure and all that?
1997 RedR - ZedR
Monday, October 01, 2007 9:39 AM
I run Purolator Gold L14006 for the first 7500 miles... then Purolator L14006 for the last 2500 ... and i use Mobil 1 5w30 Synthetic for the entire 10k miles between changes...
Monday, October 01, 2007 1:27 PM
Autozone carries the AC Delco filters. It is where I get mine. I run the PF61 on my 2.4 (for a few years now)
Monday, October 01, 2007 4:42 PM
I wouldn't run a POS Fram filter.... Delco is best, by far. It's the same manufacturer as some much more expensive brands...
Fram uses cardboard in it! Bleah...
I'm using the PF52 on my 3.8L now... supposed to be the PF47, same as the 2.2L.
Tuesday, October 02, 2007 7:20 AM
I agree with this as well. I use to live by Fram. Until I had the seal blow out. Switched to AC Delco never a issue.
Tuesday, October 02, 2007 7:49 AM
Why would I want to filter my lager, I'll just drink it straight.
_________________________
Tuesday, October 02, 2007 8:03 AM
Chris
Yes, timing chain noise, as you have no oil preser at start-up.
Chris
Tuesday, October 02, 2007 8:37 AM
Taetsch Z-24 wrote:
Chris
Chris
Only if you are using the crappy factory style tensioner.
Wednesday, October 03, 2007 5:46 PM
OK!
who makes "aftermarkit" ones for it?
Chris
