Shifted wrote:Glowing = rich
Quiklilcav wrote:You are too generalized. What do you think happens when the exhaust valve opens on an overly-rich motor? This isn't a CAI motor, combustion is not spontaneous. So, the chamber may be cooler, but that doesn't mean everything else is.Shifted wrote:Glowing = richActually, the opposite. Rich runs cooler. Lean runs much hotter.
Quiklilcav wrote:Shifted wrote:Glowing = rich
Check for a vacuum leak. That's most likely your culprit.
There is probably air getting into the engine somewhere that it's not supposed to be.
OHV notec wrote:You are too generalized. What do you think happens when the exhaust valve opens on an overly-rich motor? This isn't a CAI motor, combustion is not spontaneous. So, the chamber may be cooler, but that doesn't mean everything else is.
Think about what cars you typically see glowing manifolds on...
This can also be caused by excessively-retarded ignition timing.
Quiklilcav wrote:Any significant amount of air bypassing the TB would also cause it to idle at rediculous RPM, which would be a pretty easy diagnosis.OHV notec wrote:You are too generalized. What do you think happens when the exhaust valve opens on an overly-rich motor? This isn't a CAI motor, combustion is not spontaneous. So, the chamber may be cooler, but that doesn't mean everything else is.I speak from experience. I have seen this problem on an engine of my own before, as well as a few other motors of people I know. Every time it turned out to be a vacuum leak somewhere, whether it was a hose, or a bad gasket (caught a friend reusing a torn runner gasket on a TPI motor because he didn't think it was crucial)
Quiklilcav wrote:I'll agree that overly retarded timing could possibly be the culprit, but I can't see how it could retard that much on our engines without there being an issue of a timing chain jump, which would mean that the valve would be retarded as well.Ignition timing is what I was referring to, which could be caused by numerous things, although in this case I'd guess the knock sensor most likely.
Quiklilcav wrote:An overly rich combustion burns cooler, because it doesn't burn complete. Hence the cooler chamber temperature, as well as exhaust gas temperature. I know what you're saying, but it's an unlikely combination of events. Not impossible, but unlikely.When those unburned gases are burning in the exhaust manifold, EGTs go up.
OHV notec wrote:When those unburned gases are burning in the exhaust manifold, EGTs go up.
An overly rich combustion burns cooler because there is less relative oxygen content to feed the flame front, not necessarily because it doesn't burn completely. If you have 90% combustion at 100% fuel input, but only 80% at 120% fuel input, you still have a 6% increase in burned fuel (which using your logic would burn cooler, but in reality burning fuel = more heat). Rich engines also have cooler chamber temperatures due to liquid fuel vaporizing on chamber surfaces.
