I just did the 2.3 HO manifold sawp and i just got her running the other day and it idels around 1100 and then when i took he for a spin it fells kind of slugish. When i let off the gas it takes forever for it to idle down? do you guys have eny ideas. Thanks
99z for 2015.. I'm back bitches
You can search all my high idle threads, I seemed to have fixed mine ( at least temporarily) by unplugging the TPS sensor, disconnecting the battery, wait about an hour, hook em both back up. I did that nearly 2 weeks ago and my car has been fine ever since. KNOCK ON THE ENTIRE LUMBER YARD.
Thanks man. how do you fix this? i can be driving along and when i let off it will rev up and down for like 30 secs
might be a vacuum leak.
2004 Cavalier
13.2@105........
Mods...
BFG Drag Radials
Saab Turbo kit
2.5 exhaust, w/cutout
Spec Stage 2+ Clutch
i would deffinately check all your gaskets to make sure none got improperly seated.
Thanks guys.The stock mani is back on and its still goin the same thing, I dont see how its a Vac leak but ill check them again, ill also check the gaskets. Thanks guys. im taking the TB spacer off so that might help b/c that has a gasket. Im also thinking it getting air in between the stock mani and the head but idk why it would b/c the bolts are tight. ill try thos hits. Thanks
i checked for the Vac leak couldnt find one. the bolts on the Mani are still tight. the stock air box is back on. and i just found out that my Crouse dosnt work eather
