well im shopping around for a quiet exhaust setup.
ive tracked down part numbers and prices for most of my stuff on this list, im just looking for reassurance really that this should still be an ok setup and not be extremely loud, but yet still less restrictive and more performance oriented then the stock setup.
Item P/N Qty Price
Walker Quiet Flow3 2.25" WLK-21885 1 $90.00
Walker 2.25" Straight 10' S.S. WLK-49185 1 $110.00
J-Bends S.S. 2.25" 180* WLK-42428 4 $35.00
Cherry Bomb Glass Pack (res) 87505/10/15 1 $30.00
Vibrant 3 bolt flange 1481S 1 $30.00
Labour Estimated $100.00
Total $500.00
W/Tax $570.00
all prices are in CDN funds. just about everything is stainless steel except fr the cherrybomb resonator, its aluminized steel. all bends are mandrel bent and 2.25". the 10' straight pipe is a little overkill if im using a resonator, unfortunatly the 4' and 5' lengths ve priced out are about the same price.
im still undecided about the 10' straight and the resonator. if i dont use a resonator, the 10' straight will be fine. if i use the resonator, the 10' straight is alot of overkill. i might even just let the exhaust shop supply the straight pipe in between the bends and all that.
let me know what everyone thinks, im just looking for a second opinion and that. i would prefer to purchase all this from the parts store i use rather than ebay or something like that. i should be able to get alot of this cheaper too, as the prices i was quoted were "retail" prices.
also, the cost of labour makred down there is estimated. since im pretty much supplying everything, im not going to pay more than $150 since all they have to do is cut the pipe and weld it together.
1997 RedR - ZedR
my nice little chart got screwed up...
anyways, you can still make it out...
alos forgot to mention, im going cat back, factory exhaust manifold and factory downpipe/ cat setup.
1997 RedR - ZedR
Call up customtubes, and tell them what you want. im sure the piping with hangers and a flange would be cheaper than everything you need and its already a catback. If you want a res just cut out the length you need and weld it in.
problem though, im in canada and they are not...
i ordered my muffler today. was only $45... so far im off to a good start!
1997 RedR - ZedR
