i have a dc sport 4 2 1 header with test pipe into a 2.25 magnaflow dual exhaust i did the cat back sounded good then i did the header and it sounded awful do to not having a resonator i installed one a 18 inch magnaflow resonator and the rasp is still there when i get on it . got any ideas for me but to lwt every one know it sounds amazing!!!! besides what i have left
http://www.cardomain.com/ride/2623318
High flow cat instead of a test pipe and longer resonator should help a bit. Keep the straight through mufflers, no point in adding a header and full exhaust if you're just going to block it up at the end with baffled mufflers.
_________________________________________
450WHP Turbo Ecotec swap in the works...
All correct..
Get a cat back in there and you'll be fine.
-M
i got the same resonator, there is barely any rasp, only a very small bit when i first start it and get on it, otherwise, its perfect
12.33 @ 111.67 mph [Oct 2009]
327.6 WHP 333.6 WTQ [10.1 AFR]
check for exhaust leaks...made my car sound horrible when i had one.
My bad,
I meant, get a high flow cat in there and you'll be ok.
Those cat converters absorb a lot of the sound.
-M
pacesetter 4-1 header, magnaflow highflow cat, magnaflow 18" magnapack, magnaflow 4x8 oval muffler, magnaflow 3" tip.
evilmonkitar wrote:pacesetter 4-1 header, magnaflow highflow cat, magnaflow 18" magnapack, magnaflow 4x8 oval muffler, magnaflow 3" tip.
this sounds really good you say? I have the exact same stuff at home waiting for a spring install.
DavefromEngland wrote:evilmonkitar wrote:pacesetter 4-1 header, magnaflow highflow cat, magnaflow 18" magnapack, magnaflow 4x8 oval muffler, magnaflow 3" tip.
yea, it sounds nice. ill see if i can get a new video of my exhaust when i have some time
pacesetter 4-1....no cat. ractive muffler sounds quiet nice
kw_z24 wrote:pacesetter 4-1....no cat. ractive muffler sounds quiet nice
Maybe from inside the car.
hell its prolly loud inside the car...
If you want a non raspy exhaust your gona need a cat and bigger resonator. Im catless using a stans 4-2-1 header, 30" glasspack, and dynomax st and mines not too bad; but of course I have some rasp due to being n/a and having no cat. Mines a bit worse than it should be though, I gotta retighten all my downpipe bolts and use some lock washers.
evilmonkitar wrote:DavefromEngland wrote:evilmonkitar wrote:pacesetter 4-1 header, magnaflow highflow cat, magnaflow 18" magnapack, magnaflow 4x8 oval muffler, magnaflow 3" tip.
Cool, been wonderigin if I made the right choice, most people have larger resonators (22") around here and still some raspiness so I was worried I'd have a lot more.
so basically spend doublw what youve already spent.
get a cat....theres no reason for you not to have one. your car is not a racecar. that will help the rasp somewhat.
i have the same setup except the Rk header and i dont think it sounds all that great.
i was referring to the people telling you to replace youre mufflers, resonator ,and cat
