Finnished Ecotec Head (pics inside) - Performance Forum
Thursday, November 08, 2007 3:27 PM
Well, just wanted to show everyone my finished head for my N/A eco project.
The head consists of:
Port and Polished eco head (exhaust and combustion chambers) By me
Milled a minimum amount for a fresh gasket surface
1mm oversize stainless steel valves
GMPP duel valve springs
Ti Retainers
3-angle valve job
The whole thing including parts, assembly, and machine work came out to around 1200$. this head should be fine up to 9000 rpms. I plan on testing that out.
Ill post some pictures however there is assembly lube all over the place so it may distort some of the surfaces.
Oh yeah, and a special thanks to Karo for all his advice and slick deals!!
"Go Before Show Yo."
CARCUSTOMS.NET, THE BEST SERVICE ON THE ORG!!!
Re: Finnished Ecotec Head (pics inside)
Thursday, November 08, 2007 3:31 PM
styrofoam wont hold up to 9000 revs a minute, just kiddin, nice job and get that thing put on!!!
Thursday, November 08, 2007 3:36 PM
LOL!
On a serious note, I hate how these heads are cast
The styrofoam consistency is the same reason I didn't knife edge anything in the ports.... I don't trust the casting.
Thanks for the support!
Thursday, November 08, 2007 3:39 PM
wow... weird casting indeed.. BUT nice job man !
My Cav
I give up...
Thursday, November 08, 2007 4:17 PM
3-angle valve job
Aren't the eco's 3-angle from factory? I heard that once, just checking for validation.
Thursday, November 08, 2007 5:31 PM
i have no idea, when they cut the valve seats for the 1mm oversize valves they asked me if I wanted a 5 angle or a 3 angle..... I went with the 3.
Thursday, November 08, 2007 5:45 PM
very nice head you've got there sir.
Thursday, November 08, 2007 6:36 PM
Thanks dude, I appreciate it.
Thursday, November 08, 2007 6:58 PM
whats with the edge in the middle right side of the left port, whats the reason its not smoothed against the wall, just looks odd imo, please fill me in, thanks also, it looks great
Thursday, November 08, 2007 7:43 PM
Yeah, its all smooth... like 1000 grit smooth, its just the casting is so poor that the camera is going to play tricks. The material itself, even the color of the metal isnt even uniform. If you mean the holes that run horizontally between the ports, they are supposed to have a sharp edge.
Friday, November 09, 2007 5:58 AM
i see what he means.....its just the reflection on the metal......it does look like lik an edge.
Friday, November 09, 2007 6:04 AM
looks good by the way.
i thought the tables in HPT stop at the factory redline? how do you tune above that? (im assuming youre using hpt)
I dont have hpt yet....still doing my research.
Friday, November 09, 2007 6:05 AM
What were the gains on the flow bench? Or did you just go to town with a dremel assuming you were doing more good then harm?
Friday, November 09, 2007 6:06 AM
How much was it for the valve job and mill ?
Friday, November 09, 2007 9:57 AM
Im going to be using Electromotive TEC3R Stand alone engine management.
I haven't flow benched it yet. During my build this summer im going to flow this vs. a stock head. I followed the directions given by Standard Abrasives. They seem to believe that you don't need a flow bench to realise a gain. I really didn't remove very much material. All I did was remove the casting marks and remove the sharp edges between the machined surface and the cast surface in the valve bowl and I did a light gasket match. Then I polished everything.
I still stand by what I said in my other post that you dont need a flow bench to port at home if your not trying to re-engineer the head.
To cut the valve seats (3angle), mill, and assembly of the valve train was 280$. I thought it was a pretty reasonable deal.
Friday, November 09, 2007 10:01 AM
Here is an old shot of my Tec3r, its packed away until the spring.......
Friday, November 09, 2007 10:16 AM
looks good....thats pretty similar to what i plan to do
Friday, November 09, 2007 10:18 AM
Thanks! are you going to go for the comp stage 3 grind cams? I cant wait to assemble this thing.... they have like .456 lift!
Tuesday, November 13, 2007 8:21 AM
do you have prices/part numbers for the Valves/Springs/retainers?
Thanks!
Tuesday, November 13, 2007 9:36 AM
Nice work, I think you will be fine on the port as long as you didn't remove a lot of meat like you said, and just cleaned up production cast flaws, etc.
Mitsu TD06-20g |3" Downpipe w/ Cutout | 61mm Bored TB |
HP Tuners | Innovate WB02 | Spec Stage 3 | TurboTech Upper | Full Addco Sways | Sportlines & Yellows |
Tuesday, November 13, 2007 11:27 AM
Thanks!
I dont know thim off hand, I would contact Karo @ Carcustoms. He will be able to hook you up with the best price on these items. It will beat the price on the Ferrea equivilent by quite a bit.
I agree, I think ill be fine. Im going to flow bench it anyway but not until the spring when the motor is going together.
