i am removing the 2200 out of a 97 cav and swapping in a 2.2eco 2004 they are both 5spd. does anyone know if i need to order any aftermarket motor mounts or anything to get the motor mounted in or will i be able to use the existing 04 mounts?
by the way i have the eco out it is all attached to the o4 cradle can i bolt the whole thing up with the wheels and all or does the motor have to be removed and bolted to the 97 cradle. any help is greatly appreciated!!
Your 97 doesn't have a 2200, its the 2.2.
Anyways- heres the 2.2 to ECO swap info (yet another deleted thread that I can't take credit for).
Since Ive done this swap but from a 97 2.2 ohv. here is what you will need for a 00+
*Transmission
*Engine (obviously)
*Engine Harness
*ECU or reflash if it is possible
*Ecotec Upper Motor Mount
*Ecotec Radiator (my old 97 2.2 radiator was not as thick as this one)
*Radiator Hoses
(should be able to keep current BCM module)
Axles should work for the different trans if it is an auto (havent experimented with 5 speed yet)
You 00+ guys have it easier to do the swap considering you dont have to swap out the fuel system. Otherwise you can do what I did and replace everything if its 95-99. Suncavi got his running with the old fuel tank setup for pre 00 but his gas gauge isnt reading it properly. Thats why I opted to swap my 97 to the 00+ gas tanks and put the 00+ wiring in my car. Ran good till I put a hole in the block
Any more questions feel free to email me at streetrcn22@aol.com Im not on here too often so you would have a better chance catching me on AOL.
thanks a ton!!!!!!! now i can begin removing that slow ass pos 97
