what is the best oil filter? i thought that fram was one of the best but almost every one says it crap.
so what do you guy think? im going to be runing amsoil synthetic this time.
delco
Blew it up, build numbers coming soon
K&N or Mobil 1, I actually gain 5-10 psi in oil pressure when I use either filter over a Delco. Not dogging the delco at all either, it's a damn good filter for the money, as are Wix filters, and also Bosch oil filters.
This link rocks -
http://minimopar.knizefamily.net/oilfilterstudy.html
Edited 1 time(s). Last edited Friday, December 28, 2007 1:09 AM
I use K&N, and it seems to do the job well.
"Youth in Asia"...I don't see anything wrong with that.
the frams are crap unless you get their tough gaurd ones, but then it comes out about the same price as the more expensive ones like wix and KnN.
the ones i seem t find the best are:
-Wix
-KnN
-Mobil 1
-Champ
-Delco
-Viper
there is another really good one i like too, but cant seem to remember the name of it for the life of me....
1997 RedR - ZedR
I use Purolator with the microfiber filtering.
I will be honest. I use a walmart brand. I know walmart does not make their own oil or filters although I am not sure who does. I doubt it really matters since it never stays on the car for even 2500 miles and I use full synthetic.
i'd follow the oil filter study.
i dont believe there is actually a best, but more of "what gets the job done for said application".
if there was an actual best, then realistically we'd all use the same stuff and there wouldnt be as many replies with different answers....
thought i would post up this link to a technology champ is using now since that oil study was done.
E-Core
thats more of a press release, but still gives good info about the product.
1997 RedR - ZedR
I said Delco realizing not everyone wants to spend $10-$15 for an oil filter. Delco it is for a reasonably priced filter.
if you own a 2200, fram is best.....that super tough grip is teh only way i can get that damn filter off. whoever designed that engine should be shot.
otherwise delco seems to do pretty well
people dog fram because they use a cardboard filter or something like that
I beleive Pure-One has been proven to be (by them at least), to be the best filter when it comes to keeping your oil clean, as for keeping oil pressure up their I have no idea.
My Cav
I give up...
^^ +2 on the fram with the grip, but I only used it once, because I swapped heads and some water got in the oil and I didnt want to buy 2 KN filters.
To get the old ones off on my 2200 (K&N style) -- I used to use a sheet of 60 grit sand paper and wrap that on it and it would come off nicely. Now I have a set of gloves I can't remember where i got them, but theyre really grippy and I only use them on the oil filter. (this is jamming my arm behind the PS pump, doing it from the top.)
I use K&N, Never have the patience to go get a delco filter, autozone is like 12 ft from my apt.
Machzel08 (Teh Jew) wrote:if you own a 2200, fram is best.....that super tough grip is teh only way i can get that damn filter off. whoever designed that engine should be shot.
Yeah, I have to use the Fram with the grip on my sister's '02 2200 because of the ECU, but if the ECU is removed it's not too hard to get at.
The other vehicles get Delco.
i dont why you guys have so many problems with changing the filter on the ohv... jack up the passenger side, lay behind the passenger tire, reach up and yank it out. but maybe that only works on the 5 speed... my 89 had that f'n sweet extension, put the filter (literally) in the wheel well.
K&N no contest...those filters are built like a brick stackhouse!
Goodbye Callisto & Skaši, Hello Ishara:
2022 Kia Stinger GT2 AWD
The only thing every single person from every single walk of life on earth can truly say
they have in common is that their country is run by a bunch of fargin iceholes.
As long as you change it on a regular basis, it doesn't really make a difference..
Personally, I get AC Delco filters from the dealer... but I get staff rate b/c my Mum works there
So they're cheap.... but I use the longer application ones... ie. PF-59 for the 2.4L, instead of the PF-44.. (or 47 or whatever). PF-52 on the 3.8L instead of the PF-47..
I might have those numbers mixed up... but either way, it's a longer filter. I still change it every 3k miles.
...j
Rich Grayo Jr. wrote:i dont why you guys have so many problems with changing the filter on the ohv... jack up the passenger side, lay behind the passenger tire, reach up and yank it out. but maybe that only works on the 5 speed... my 89 had that f'n sweet extension, put the filter (literally) in the wheel well.
autos dont have that nice easy access....well we do but not as easy
Generally all are "good." But one thing you should look for is Microns and the lower number is the better, another is a "Anti-drainback valve." With that said FRAM's "Extra Guard" removes particles as small as 10 Microns, AC Delco's is at 25. I'm using Delco's for now because I bought like 7 for $1.00 each so i had to use them up. K&N is at 10 microns too. Moroso's filters at 20. Ford's Motorcraft is a 25.
ACdelco used to have the Gold series, but I have not seen that in quite a bit and they had it rated at 10 Microns. I am up to my last Delco filter and I am going with FRAM Extra "Guard" next. I <3 ACDelco because of the anti drain back, but i have to test the Fram.
>>>For Sale? Clicky!<<<
Rich Grayo Jr. wrote:but maybe that only works on the 5 speed...
I could pull that off with my 3-speed, but not so much with the 4-speed.
Wade Jarvis wrote:I will be honest. I use a walmart brand. I know walmart does not make their own oil or filters although I am not sure who does. I doubt it really matters since it never stays on the car for even 2500 miles and I use full synthetic.
As long as the certs are on there, you can rest pretty much assured it's just as good as any other synthetic.
I use Pennzoil and Fram filters. I'm gonna try out the Fram Synthetic filters to see if they're worth the double-price tag of a regular filter (triple of a no-name brand filter).
2002 Sunfire -->
- Ractive steering wheel
- ASA 17" EM9 + Nexen N5000 215/45/17 (steelies for winter)
- D-Spec Lowering kit @ 1.4" (issues currently
- Rockford P250.1 + MTX MZS1004 + Panasonic CQ-C8313U head unit
- Barely legal tint.
