Josh F wrote:whitegoose( RedR-ZedR) wrote:this is what i use....
original filter
Champ PH44
Applications
American Motors (1983-86), GM Products (1975-77, 96-08), Jeep (1983-86) (GM 25010633)
Dimensions
Description....... Inches ........MM
O.D.: ....................3.00........ [76mm]
Height: ................3.11........ [79mm]
I.D.: .....................13/16"-16 Thd.
PSI Relief: ..........None
Anti-Drain:........... Yes
Larger Filter
PH51A
Applications
GM Products (1980-05), Isuzu (1997-99) (AC PF52; GM 25012760)
Dimensions
Description........ Inches........ MM
O.D.: .....................3.00........... [76mm]
Height: .................4.44 ...........[113mm]
I.D.: .......................M18 x 1.5 Thd.
PSI Relief: ...........None
Anti-Drain: ...........Yes
if you really want to do some major cross referencing....
http://www.champlabs.com/contact/support.html
call the filter hotline.
thanks for that... so is it the 18 x 1.5 or the 13/16" - 16 thread? for the stock thread
Snowman wrote:wow i dont know that,
the guys(idiots i presume) that changed my oil @ the pontiac dealer always used the bigger filter.
and i never had a problem.
bigger is better... to a point... it definatly wont hurt and thing
in the past when i called the filter hotline, they have told me that the if there is physical room, the larger filter will work....
here is the problem though.
i posted up the wrong larger filter.
so
2.4 LD9
ORIGINAL FILTER
PH44
Applications
Dimensions
Description...... Inches...... MM
O.D.: ...................3.00........ [76mm]
Height: ...............3.11........ [79mm]
I.D.: ....................13/16"-16 Thd.
PSI Relief: .........None
Anti-Drain: .........Yes
LARGER FILTER
PH59
Applications
Cadillac (1972-08), GM Trucks (1999-08), Oldsmobile (1970-90, 95-04), Pontiac (1978-99, 2004-08) (AC PF59)
Dimensions
Description..... Inches..... MM
O.D.: ..................2.97 .........[75mm]
Height:.............. 4.44 .........[113mm]
I.D.: .................13/16-16NS Thd.
PSI Relief:............ No
2.2/2200 LN2
ORIGINAL
PH47
Applications
American Motors (1980-84), GM Products (1975-08), Isuzu (1989-94, 96-03) (AC PF47; GM 6439929, 25010792)
Dimensions
Description .......Inches ......MM
O.D.: ...................2.96....... [75mm]
Height: ...............3.11....... [79mm]
I.D.: .....................M18 x 1.5 Thd.
LARGER
PH51A
Dimensions
O.D.: ...................3.00 .......[76mm]
Height: ...............4.44....... [113mm]
as for the Fram PH3506 and the Wix 51042, the cross reference to the Champ PH44.
the Napa Gold 1522 cross ref's to the PH59 Champ.
the Delco PF61 cross ref's to the Champ PH59, has an anti drain back.
if a filter is installed properly and has a good gasket, then it shouldnt go anywhere or spin off. its possible the gasket or threads were slightly different in length and the filter was bottoming out, not creating enough clamping force on the gasket of the filter to keep it on.
ive been using my larger filter for a while now and i do race it and haent had any problems as of yet.
1997 RedR - ZedR
