hey guys, i know you are all pros here in regards with the j body, so here's my thing..i have a 97 model 2.2L engine with injen intake and pacestter header.I know that it's useless to upgrade cams without upgrading the header. my question is from which model or car can I use "performance" cams for the 2.2L. I've tried looking online but nobody ships to my place. anyone out there willing to send me cams here in the middle east????otherwise, teach me where I can get those.thanks a lot...
Have you considered buying a used cam from someone in the states and paying for shipment to Crane or another company willing to do a regrind, then having the cam shipped to you? It might be the easiest route.
-->Slow
actually, im here in the middle east, so...anyone there who has used "performance cams" for the 2.2L 97 4 door cavy????i've tried to browse for shops online but nobody ships here.
jbody performance has them i think
Rich Grayo Jr. wrote:be wary of ipp cams.
what are those???I just inquired to them..bogus?
what's wrong with their cams??
if i have a used stock cam and want to regrind it, what would I tell or what specs should i have it done??i don't understand those numbers..
MadJack wrote:IPP says their cams are made from a billet core, but they are a solid casting. They should be okay with stock springs, if they are properly hardened. The J-Body Performance (JBP) cams are way overpriced regrinds. You can get a stock cam reground for between $110 to $165, depending between the cam companies, using their existing lobe profiles. The dimensions on the LN2 cam lobes are the same as the SBC hydraulic roller cam lobes, so whatever lobes are available for the SBC, you can get done to the LN2. There will be limits to what you can do, due to the dimensions of the stock cam profile.
Absolutely.
I did a good bit of business with IPP, but the company that makes thier cams (webcams) is an unfamiliar company with a price that is to good to be true, for the exact reason stated above. I dont know anyone who has run one, but I personally would not trust it.
IPP is a fairly priced company for some harder to find and custom j-body performance parts, but the staff does not know what they are talking about all the time, and they did over charge me 2 times I ordered from them (they did refund the overcharge)
wow i was wanting to get the stage 2 cam for my 96 LN2 motor. of course i need to add the 1.6RR to it. but i might have to get a regrind here in town.
I would be amazed if someone in town could do that....
Mine was done by Crane Cams.....I have also heard of Crower doing them....or if you feel like wasting more money than needed, you could get one from JBP....
I wouldnt trust just anyone with it though, I am pretty sure most machine shops cant handle that...
ya on 2nd thought most of the machine shops here are limited, bu it doesn't hurt to ask i guess
MadJack wrote:Actually, Web Cams isn't that bad of a company, they specialize in import and OHC camshafts, not OHV cams.
Correct, I have a set of their DSM cams ("stage II"). The DSM community is very critical of their work, with early quality control problems, and sub-par dyno results.
Okay then... Who do we trust for a fresh grind instead of a regrind?
Go beyond the "bolt-on".
so who has ipp cams on their 2.2L 97 cavy??? i don't think i have an option since they are the only ones shipping to middle east. all my friends have civic and want to show them our cavy has potentials!!!!am always trying to tell them about 8 second cavys like lisa kubo's....like i've read somewhere in one of the post quote"damn this civics"
. am also planning now about the HPtuners as well but i need to work on my internals first. how about pistons, which one you guys would recommend???????one more thing, what's the size of our piston??
Nickelin Dimer wrote:Okay then... Who do we trust for a fresh grind instead of a regrind?
Well, you can talk to Dan (JuicedZ4)... he got a billet cam made by..... Comp? I think? And ground to his specs, but it'll cost you over $800 clams to get it. That's probably the route I'm going to go, but I need to work on getting a motor into the shop to build first.
Arrival Blue 04 LS Sport
Eco
Turbo
Megasquirt
'Nuff said
If you need a 2200, you can buy the one my friend is holding on to. $150.00 cash but you'll hafta come pick it up (no exceptions on that rule).
Ha, thanks Dime, but I can get plenty of em out of the local yards without having to drive out to Illinois
Eco
Turbo
Megasquirt
'Nuff said
anyone out there can tell me what to tell the cam "re-grinder" about the specs or numbers to give??
ssome one sell me a custom grinded cam ill pay what you payed for it + shipping even if its used
