Well i guess i just need to know how. From what I have read you just stick a metal pin in beside one of the wires on the tps Iam not sure what color tho. then ground the volt meter and put it on the pin you put in the wire. then turn the key to the on position .
BUT.
What should the volts be closed and what should the be around at WOT?
Any tips would be great.
Thank You,
Paul
100% throttle = ~5V
0% Throttle = <.05V (I believe it's around .02V)
You should just have to attatch the leads across the blue signal wire and black ground wire.
"Youth in Asia"...I don't see anything wrong with that.
