3800 high idle - Performance Forum
3800 high idle
Tuesday, January 01, 2008 5:28 PM
this is probably not the right place to ask this as alot of ppl on here have 3800 in there cavaliers
my wifes 89 oldsmobile 98 regency brougham 3800 automatic idles around 1500 rpm my question is what could cause this
a bad maf
a bad tps
it has a new air filter, fuel pump, fuel filter plugs wires
what else could cause it to idel so high?
Re: 3800 high idle
Tuesday, January 01, 2008 5:35 PM
air leak.
Re: 3800 high idle
Tuesday, January 01, 2008 6:11 PM
MAF, TPS, vacuum leak. All possibilities. TPS and vacuum leak are fairly easy to test. TPS can be tested with a multimeter. Vacuum leak, just start checking all hoses, etc. to see if you can find someplace drawing in air. A real quick test is to pull off the intake duct and put something over the throttle body. If the engine doesn't stall out, you have a vacuum leak somewhere.
Re: 3800 high idle
Tuesday, January 01, 2008 9:08 PM
thanks
does any one know what the tps should read on a multimeter
and how would i check to see if the maf is functioning properly
Re: 3800 high idle
Tuesday, January 01, 2008 11:16 PM
I think about .6 to .7V with throttle closed and around 4.7V wide open.
It should idle high when it's cold. My GTP idles up around that area when you start it in the cold. But as the engine warms up the IAC will let the idle back down til it's back to about 600-700.
Re: 3800 high idle
Tuesday, January 01, 2008 11:37 PM
at full running temp the engine still idles reletivly high and shakes the car yet there is no "notable movement of the engine"
Re: 3800 high idle
Wednesday, January 02, 2008 4:51 AM
I forgot to add one thing. It might need something as simple as an idle relearn. Every motor is a little bit different, so check on Autozone.com for that. It should be listed in the troubleshooting section of the manual.
