I need to built my engine very soon and I am thinking of these parts, a very similar configuration to the friend Frikken:
wiseco pistons 9:1 .020 overbore
eagle rods
clevitte bearings
2.3 oil swap
carcustoms valves
Port and pulish head
Rksport 4-2-1 header
secret cams
Spec Flywheel
Spec Stage 3 Clutch
that they can say? using a supercharger kit M-45
Can nobody give an idea?
for that read lately lower compression considerably it is not convenient using the supercharger M-45, now I have maximum 7 psi with ALKY injection.
I think maybe it would help if you said what ttpe of engine you plan to build.
Go beyond the "bolt-on".
Nickelin Dimer wrote:I think maybe it would help if you said what ttpe of engine you plan to build.
just click on the dudes profile. it lists his car. GOSH!!
Mario
dont forget to balance your crank. seems you have a decent list of parts
I went 10:1 on my S/C build.
Yes friends my engine is a 2.4L LD9 year 2000.
mitdr774:
you mean that my future CR is very low for the supercharger? Do you believe that I will lose power?
Mario Peluso wrote:Yes friends my engine is a 2.4L LD9 year 2000.
mitdr774:
Stcok your CR was 9.7:1 Yes the you will lose power if you go with 9:1 instead of 10:1 10:1 FTW
really is the power loss that much? As i'm doing the same build pretty much...just a little more in depth. Wade knows i harrass him everyday!
Thanks man!
, but is it that much?...i know the good thing is we'll be set-up if we want to go with a bigger turbo, or a bigger charger.
"If you have no clue what's going on... STFU!"
wow...he wants to use 9:1 pistons with a supercharger thats designed for a 9.7:1 piston....sounds like a BAD idea to me...if the charger on the 2.4 is rated at 200 hp...if you go with 9:1 count on making a good 180-190hp...and why would you want to do that??? since your going with forged pistons go with 10:1 and stop worrying about it !!
