I am looking for info on the m nuetral shaft install.  Like will i need bearings or anything else?  Also can these shafts be installed in another engine after being run in aother one? any help or direction would be great..phil
what engine are you working with ?  in your profile it says you have a 2.2OHV?
eco is what im working with...i used to have the 2200..eco swap ftw
^^^I know where to buy then. Im looking for info on install and if they can be transfered to another block..anyone?
You mean installing a set up used ones? I dont see a problem with it... not much can go wrong with them...
yes..i plan on buying a set from you in my motor and then swapping them over to my built engine when it is done in a year or so.
might want to check out the gm build book
I'd contact levelzero.  He makes a balance shaft delete kit so you can reduce the mass as well.  This is what I just finished installing while I'm building my motor.  You keep the sprockets and front bearings.  He sends you a set of mid bearing inserts and a set of cut-off and polished shafts so the waterpump/balance shaft chain still has something to turn on.
The GMR delete kit still requires you to fabricate the blockoffs and costs a good penny more, but it includes a shorter chain.
-Chris
impossible to do without first removing the engine
the passenger side wheel well is in the way
IamRascal wrote:I'd contact levelzero.  He makes a balance shaft delete kit so you can reduce the mass as well.  This is what I just finished installing while I'm building my motor.  You keep the sprockets and front bearings.  He sends you a set of mid bearing inserts and a set of cut-off and polished shafts so the waterpump/balance shaft chain still has something to turn on.
What?  block offs? GMR delete?  Im talking nuetral shafts.
I had the lzm kit..i sold it cause i did not like certain things about it.
And pj...engine is out of the car..
You should be fine then. Long as both engines are out I dont see a problem with the shafts being used and reused again in a new engine. Long as you dont damage them by dropping it or something I think you will be fine.
Karo knows
 He has been selling them for years.  Also, verify how the "bearings" look in the original block, if they measure well and look to be in good condition, you should be okay.
-Aaron
www.TurboTechRacing.com
Yup..ill be ordering some from karo soon..
Philly D wrote:What?  block offs? GMR delete?  Im talking nuetral shafts.
Don't know what you found to be wrong with the kit really simple and effective design.  I thought it was great.
I just don't see the point in leaving tha extra weight in the car.  Your engine still has to rotate it even if its not helping down the vibrations anymore.
-Chris
Yes the thing i did not like was the sideways torque put on the bearing.  I know there has not been issues with them going..but i made a decision to not go with that kit..no big deal really and isnt me putting down lzm...in all honesty it was also cause id like to transfer to my built motor later on.  Also with lightned flywheel,clutch,crank and alt pulleys, and nuetral shafts..i think itll rev fast enough.
