do you have a turbo?  cause that paragraph states "For Turbo Applications Only"
Seeing as you are not turboed, there would be no use for this.
well i see u guys were no help. if u must know then yes i am working on getting a turbo set up going. i simply asked the question because there is only two other aluminum fab. intake manifolds out there for an ecotec   the GM performance one and the AirForced.
Scott A wrote:well i see u guys were no help. if u must know then yes i am working on getting a turbo set up going. i simply asked the question because there is only two other aluminum fab. intake manifolds out there for an ecotec   the GM performance one and the AirForced.
Be more specific next time.
maybe if you would of gave us a little info in the first place like you doing a turbo setup  then maybe we could of helped you more.
