ok i new here ive searched a lot and yes i know this has been posted a lot but i cant find any post with all the parts that i would need to swap my 2.2 to a 2.4 in my 97 cavy 5 speed. thanks in advice
Well, you'll need the motor mounts, the transmission, and all the wiring.
_________________________
you should swap to the newer 2.2 ecotec, although I still love my Quad... the 2.4
GMR has got nothing on this
^^^I'm def. going to have to agree there, the eco will have more parts available in years to come and is basically intended to be boosted.
Plus, the Ecotec will last way longer even just from day-to-day than the old Quad4 ever could. But then, if all that's involved seems like too much for you to do, you can always build the 2.2L. There are plenty of guys here that'll each give you plenty of tips on how to. Just search: 2.2L, 2200 or LN2 to find out what. Good luck!
Go beyond the "bolt-on".
don't do an engine swap thats to much work just bye a chevy with a more powerful engine
ok sorry in advance if i spelled something wrong i used the wrong word and plese do correct me if I am wrong
any ways all jokes aside the biggest thing i think every one missed is a pcm (pce, computer) this is crutial because it controls/ monitors virtualy everything about the engine and also controls the transmission.
if an engine swap is more the direction yuou want to go new 2.2L ecotech is a much better choice with a few tweeks it's just a powerful as the 2.4l ld9 quad 4 and like others have said more parts should be available for it in the future plus
with the L61 or L42 the power band seems to be wider with 148 hp @ 5600 RPM 152 ft·lbf @ 4000 RPM with intake and exhaust it should be around 150-160 hp or the 2.4l LE5 which boasts 25 hp gain over the ld9 series engine but thes engines are available in less of the production modles and parts are going to be a lot lee available
i hope this helps
P.S.only correct me if i am wrong i know i probably spelled something wrong i usually do
If old, important threads could somehow be kept from getting deleted, maybe you wouldn't have to ask questions like this. Its a good thing I backed it up on my HD.
I did not write this, and unfortunately, since the thread was deleted
, I can't simply post a link. I also have the How To for a 2.2 to ECO swap if anyone is interested.
This is exactly what you need and you will also need the PCM out of a manual or just get your friends VIN number or someones that has a manual and take yours to dealership and they will reprogram it.
*2.4L tranny
*Tranny mounts
*bolts for the tranny mounts
*bolts that go through the mounts
*Chassis brackets (need to be MIG or TIG welded)
*Flywheel
*Flywheel to crank bolts
*Pressure plate
*pressure plate to flywheel bolts
*clutch plate
*alignment tool
*slave cylinder
*Both axels
*Complete front wiring harness(different sensors)
*ECU reprogrammed by GM
*Shifter
*shifting cables
*shifting cables bracket
*bolts to mount shifting cable bracket
*clutch pedal
*master cylinder with reservoar and lines
That is pretty much it, and knowing how to make it all work
Many people don't even think about the wiring harness but when you look at the plug in 4 speed trannies it has about 10-12 wires going to it and a couple of more sensors and a manual has only 2 sensors. If you cannot get the whole wiring harness because it is expensive or something, just get the VSS pigtail off a 5 speed and the reverse taillight pigtail (those are the only pigtails on the tranny), and I will let you know how to hook those up on your automatic wiring harness.
Manual tranny has mounts on it and these mounts are bolted on to these brackets that are welded on your chassis. So, that's what automatics lack (the brackets) You are gonna need the junk yard to hack them off the old car so you can weld them on yours. Also, you are gonna need to drill a hole in your firewall for the master cylinder. Also, you are going to need to bend your front driver brake line, but don’t break it!!!!
Bleed you clutch and your brakes and take it for a spin!! As you can see, I didn’t write that you have to take the dashboard off and your brake master cylinder and stuff because if you don’t know that all that has to come off, you should not be doing the swap. Also, in automatics, there is this one like a shifting cable that is under your carpet and it goes from your auto shifter to the ignition, that is there to prevent an auto tranny to be shifted by you if the keys are not in the ignition. Don’t fuk with it, just disconnect it and leave it where it is because it is somehow connected with the damn ignition and you are going to have to put ignition apart to be able to pull it off. Also, the clutch pedal sensor: The way you are going to wire this is, there are 2 wires coming out of the pedal sensor, one yellow and one purple. There is a thick yellow wire coming out of your ignition, on the left side of the steering wheel and splice the pedal yellow into ignition yellow.
Purple goes to the engine bay, right under your clutch master cylinder (now you have one since you came this far with the swap ), your wiring harness plugs one into another and there is a think yellow wire there and that is where the purple from the pedal plugs in. The thick yellow wire is there with another 40 wires and another at least 3 yellows, but a hint to be able to find it is, it is in one of the corners, all the way in the corner and it is beefy.
If you wanna over ride the sensor, so that you don’t have to push in the clutch every time you start the car, just connect those 2 wires where the pedal sensor is and pull the sensor out. Make sure that if you bypass this every time before you start the car and the clutch is not applied, the tranny has to be out of the gear, because the car ‘’’WILL’’’ jump!!!
All in all the work is not that bad when you think about it. LOL
I have swapped my car from a 2.2 3 speed to a 2.4 4 speed and now I am swapping in into a 5 speed and I did all this. I have done a total of 4 swaps on Cavies including mine and all of that were manuals beside mine, so I know what I am taking about. LOL
Trust me if you are not very mechanicly inclined don't even think about performing something like this by yourself just because your friend that owns a Civic told you that it is not hard. (I had to do this)
By the way you got to decide weather you wanna go with the Isuzu tranny or Getrag because those brackets for the mounts that you are gonna need to have welded, in Getrag are 5 inches more apart than in Isuzu, and shifter and shifter cablets, etc…. are different.
If you do go with the eco, just dont go LSJ on it...slap a TURBo instead.
Thanks James for that write up... I will be doing a similar swap in a 96 sunfire.... (difference is I have a full donor car (my old one which was killed by my brother after slideing into a tree.)
Biggest question I have is what is the easiest what to remove the engine and transmission in these cars, up out the top, or through the bottom?
