how high can a stock 2.2 non eco tec rev if i were to disable the rev limiter?
If you don't know the answer then there's no need to rev higher.
There's no need the raise the rev limiter if you don't have supporting mods to make power in higher rpm anyway.
2300 RPM... i have no idea why GM even set it as high as they did.
1997 Cavalier Z24 - 16.3 in 1320 and falling...
how're you going to disable the rev limiter exactly?
answer that question first.
just hit the fuel cut off i do all the time lol! hasnt blown in 3 years so i must be alright ahah
Zany higher then 6250 will probably destroy the engine. Honestly, the engine is suffering at the stock rev limited. 6300 would probably cause valve float. If you upgraded the lifters, valve springs, pushrods, roller rockers, you might be able to get as far as 6500. Unless you get customs lifters, dont expect anything. Unless you get a cam regrind, there is no reason, the engine makes most power below 5500 rpm. Power starts to fall after 5000 rpm.
whitegoose( RedR-ZedR) wrote:2300 RPM... i have no idea why GM even set it as high as they did.
Lmao
I'd say you might be able to hit 6500 before blowing it. The head REALLY wasn't built for high rpms.
_________________________
DaFlyinSkwirl (PJ) - APU wrote:how're you going to disable the rev limiter exactly?
^^^^ X2
hondas are like tampons.....every pu$$y needs one...
mildly built 99' ln2, eagle h-beam rods, wiseco forged alum. pistons, cusco oil catch, t3/t4 super 60 garret, tial 40 mm wastegate, hp tuners, prothane mount inserts, 2.5" exhaust.
Here are instructions for disabling rev. limiter.
Mitsu TD06-20g |3" Downpipe w/ Cutout | 61mm Bored TB |
HP Tuners | Innovate WB02 | Spec Stage 3 | TurboTech Upper | Full Addco Sways | Sportlines & Yellows |
I'd like to know what you're doing to still be making power past 6,000 rpm.
BlackEco wrote:Here are instructions for disabling rev. limiter.
LMAO!!
thats the best diagram EVER
^^^ This is a joke right? somebody is playing you all. he can't be serious
just trying to be better safe than sorry, didnt mean to sound stupid or anything i
thought maybe sice it was an l4 it could rev higher than my camaro apparently not.
is an american car so no need to go past 6k rpm lol, besides theres not much power past that. go buy a honda if you wanna rev past 6500 rpm .
^^^ yes there is. Not on a stock engine but it can be had.
Tell ya what, do a full build and bore your intake and exhaust valves out 2mm AND THEN rev it (I'd bet you could make power up to 8k if done right). It'd actually be pretty cool to see a 2.2l boosted running up to 8k.
what is everyone's obsession with revving? lol. especially those with ohv.
I drove a buddies 02 4 door and i thought the tach broke because it got to 4500 and seemed to be stuck until I shifted and the rpms began to increase again.
