I'm piecing together an exhaust setup and I just recieved my pacesetter header and i'm wondering about that extra little pipe on the end....i'v read that in the 2000+ they don't use this any more....is this true....if soo how can i modify this to fit? Oh and i have a 2000 LD9 motor.
thanks, Chris
2000 z24 Cavalier
If your talkin about the piece that bolts to the header (downpipe). I have a 02 2.4 and I had a problem with the header install. The downpipe piece fit but would go thru the firewall. so, the muffler shop just made a custom pipe with more bend in it to go underneath the firewall.
na it's the little piece that comes off one of the pipes up by the engine ......i think it's called the egr valve??
2000 z24 Cavalier
Should have ordered the proper 2000 plus pacesetter, mine didnt have any extra piping off the header
yea i thouhgt i did i even called them to ask them about it and they said the header is for a 99-02.....how do i fix this?
2000 z24 Cavalier
That link is asking for a password
opps i'm att work and on a proxey server
....... i'll just get a pic of the one i have when i get home..... either way the user name for the above link is
csr and the password is
Cust0^^3r....
thanks, chris
2000 z24 Cavalier
the piece that i'm talking about is circle in this header( not the one i have but similar)
....... So will this fit or will i have to get a new gasket or reuse the one i have????
Thanks, Chris
2000 z24 Cavalier
anyone????
2000 z24 Cavalier
Should be safe using your current year's gasket, the EGR tube just wont be used. IIRC there's just a block off plate on the block for it, and the gasket does the same on the exhaust side.
Ender_Wiggin wrote:Should be safe using your current year's gasket, the EGR tube just wont be used. IIRC there's just a block off plate on the block for it, and the gasket does the same on the exhaust side.
All the gaskets are the same... It is all in the "header" for the EGR port, you need to get one proper for your year.
-Aaron
www.TurboTechRacing.com
just use a 00+ exhaust gasket. That is exactly what I did with mine, and the guy I sold it to did the same thing. The 96-99 have an opening for the gas to flow through the head to the EGR valve. The gasket on the 00-02 engines does not have this opening. The correct gasket for your car will block off the EGR passage.
