Do anybody know of any fuel injectors capable of running 50/50 mix Water injection. RC engineering doesn't but I found injectors that can run 100% meth but nobody says they can run a 50/50 mix. Understandably because they don't want their injectors failing on their customers after saying it will work. RC told me it would work if I picked them with fuel afterwards but that will require another solenoid. Basically, I wondering if anybody has had any experience with this? I'm thinking I will just use stockers from junk yards and replace when they go out......I can get them for $10.00 a set and If they last 6months or so I'd be fine with that.
Go look around for something called "Water Injection". Such a system has been around for years & will handle the mix you speak of. It's been done before.
Go beyond the "bolt-on".
^LOL...ya, I want to do it alittle different. I've run those nozzles, they suck at low flow rates and the whole PMW motor drive to regulate pressure/flowrate is just horrible. With a pump full on and a pressure regulator with injectors will run soooo much better than those nozzles...If you have ever dyno'd a water injection nozzle you will know what I'm talking about....(any brand, you name it, low rates and they spit, not mist.) At low pressures that are required for the low rate the flow rate is horrible and unpredictable.
I have all the parts to do it with injectors, including good injectors(not made for it per-say) and it was still cheeper than a modest WI kit.
So if anybody knows of some injector brands please let me know.
Edited 1 time(s). Last edited Monday, March 24, 2008 5:28 PM
I would say, use some stock injectors. Why waste the money on high dollar injectors when the water is going to eat them up.
I can also vouch for the nozzles not being the best way to inject fluid. When they turn off they dribble water til there is no more water in the line.
