Im driving an 04 sunfire LS
i would like to re-do my exhaust, but need a little help piecing it together
I would also like to turn it into dual exhaust.
Pacesetter ceramic coated header is a definite, and perferably everything else MAGNAFLOW
i was also thinking of going with 2.5" setup, only other engine mod is a ram air intake, no others planned
if someone can offer advice on what components to use, (part numbers would be appreciated)
Thanx in advance, Jay
from what ive heard, if your not turbo'd, your better off going with 2.25" instead of 2.5 due to exhaust velocity.
________________________________________________________________
1997 4 door black sunfire - 2200 - 335,xxx KM's
Mods : GrandAm Wing...more to come..
1997 2 door white cavy - 2200 - 175,xxx KM's
Mods : Nothing yet....
taking the 2200 out of the cavy and throwing it into the sunfire, taking the 3100 out of my friends GrandAm and throwing it into the cavy. XD  Definatly a work in process...
If you have no other engine mods planned, then go with 2.25".  It will flow enough on a stock engine.  A 2.5" would actually be overkill.  If you want duals and magnaflow, then just get the magnaflow dual system and a resonator.
Edited 1 time(s). Last edited Wednesday, April 02, 2008 6:22 AM
Come to Port Byron, NY. We can hook you up with a good priced 2.5" SS cat back with dynomax super turbo muffler installed.
well im open to input on whether you guys think 2.25 is better or 2.5
and im from Toronto Canada, no shot im driving to NY, but thanx
2.25 it is then
i will be getting the magnaflow hi flow cat, 94035
but i still need a bit of helping picking out the mufflers,
any advice appreciated
anybody have input on going with this muffler...
Magnaflow part number 14325
im really a noob here and need a little input
thanx, Jay
looks like a decent muffler.
http://www.magnaflow.com/02product/shopexd.asp?zone=main&id=6937
Its chambered so thats key to a non raspy/Honda-ish sound. So IMO your good to go. Scoop up 2 of those bad boys and buy 2-4" tips. Now whether your going to do this yourself or get someone to install it for you is another question....as for the piping, im not sure of the shops around Woodbridge but I know someone in the Canadian Mid East forum could help you out with a good shop in the T.O area to fab this up for you. You should also look into geting a resonator of some sort. Probably atleast 14" in length if not larger. Hope this helps.
thanx for the info
i was thinking about getting an 18" resonator, and having all of it installed at NOYZE BOYZ in scarborough, heard the are great, but im open to ther places
make a post on canadian mid east forum under regional forums on this site and ask about good shops, maybe they will confrim the one you have in mind. I can't wait to hear the results. Make sure u get a clip of it if you can.
