what I have been up to.... 2.2OHV content inside :eek: - Performance Forum
Thursday, April 10, 2008 12:40 PM
Im cross posting most of the from a local forum. So it will seem a bit jumpy, but youll figure it out. I will split up individual day's posts with numbers. This only goes back a month or so and doesnt include any of the new motor pics etc. I think I posted those up somewhere last summer/fall.
1.
figured I should just start one post for anything that I have done, or will be doing this winter.
So far I managed to get the trans out and fixed the non-shifting 3/4 gear. That is all back in and working now.
I also pulled out the engine harness in prep for installing mega squirt, MSD DIS-2, and moving the factory DIS module off the back of the block (more on that next week probably)
Next, I am finally getting around to making radiator/IC ducting. The stock z24 v6 cars had a plastic duct that helped to direct air from the GM "flap" up into the radiator as there are no cutouts in the bumper or grille. Given the fact that Im using an aftermarket radiator and I have an IC in the way, I decided to make my own.
Here is what I have so far.
I still need to trim a tiny bit more out of the bumper support so I can fit a piece between the top of the opening and the top of the IC in. Also need to fab up a coulpe of "wings" to sorta fill in the rest of the bumper cutout and to increase (or maybee decrease) the size of the IC opening. Then get it riveted up etc.
2.
almost done, minus riveting and lower mounting features.
I need to trim the bumper to put the top piece in here. I put my paper template in quick just for reference.
I will probably also add a piece from the bottom of the bumper opening to the bottom of hte IC core, a mirror of the top piece more or less.
I think I need to make a quick piece that fits up in there under the top IC pipe. I was gonna just leave it, but itll be easy enough to put another piece in there when its out of the car.
I forgot to grab a pic of it witht he bumper cover on, but basically this fills up the entire mouth of the cover now.
3.
Took a few quick pics with the bumper cover sorta sitting in place.
4.
Ok, the ducting is pretty well done. I need to make two mouting tabs for hte bottom of the radiator, and add some new holes to attach the inside of hte mouth of the bumper cover to the inner support. But pretty much it done. I do need to clean up the marker lines etc, but its too fn late right now.
Some pics with the clecos installed, test fitting etc.
And all finished up, minus what I mentioned above, and "in".
Ill prob post up some more pics once I have the bumper back on. Until then moving on to the next project. Coil relocation and MSD DIS-2 / Mega squirt install.
5.
Getting back to other stuff now. I finished up the relocation mount for the ignition module and coil pack today. Also my shorted wires came back from Magnecor. They charged me like 10 bux plus 8 ship to shorten the set. I think I lost about 15" from each wire with the relocation.
I also got the MSD box mounted. Im using some neoprene standoffs to attempt to keep the MSD box in one piece. I think they were like 1.50 ea from McMaster. MSD wants like 15 bux for a set. Plus I had to use all diff lenghts.
6.
Got the rev 2 heatshield made and almost all on tonight. I just need to weld on the standoffs but ran out og gas, ugh. Its 0.030" ss that i finally remembered I got like 5 years ago. I rolled it at my buddies dad's place.
Also I got most of the MS wired up. It should, along with the charge pipe , be done tomorrow.
7.
Not a ton of progress today as I had to work at the shop and switch two sets of wheels etc etc.
Anyway, I have the MS just about all wired up. Im short a couple of sockets for the firewall connector and the chassis connector. Mainly the inside portion is done. I also got the engine harness taken apart and the coil pack wiring extended and a few other things cleaned up and some unused wires removed.
Tomorrow's plan
- Get engine harness finished up, loomed, and reinstalled
- Connect MS to car and see if I can see the sensors, cal throttle etc (dep on what wires I cant hook up yet due to the lack of pins)
- Finish welding on standoffs for cold side charge pipe heat shield
- Finish last 3" of weld on the filter tube
- blast, paint and reinstall upper water neck
- whatever else there is time for.
Stupid wiring pics
The two connectors are for the firewall, the single one connects all the gauge senors and MS to the car (power etc). The relay, which is the only relay not in my main power dist panel is for the timing bypass, basically to lock timing at 10deg.
yes, I measured every piece of heat shrink, and I still need to add a backshell. I didnt like the one that was sent with the MS. Ill grab a nice one at work monday.
Engine harness (well, most of it)
8.
Lots more done today. I think I may have even hit the whole list.
MS is all wired and in the car, minus the few sockets i still need.
Engine harness is all redone, loomed, and installed.
Charge pipe heat shield standoffs welded, just add powdercoat.
Filter tube welded. Id like to just tig over it quick before I get it coated as well.
Upper water neck sandblasted, beaded and painted and installed with the new silicone upper radiator hose ( so glad to be rid of the universal rubber spiral hose bs)
I wanted to finally bead the tubing on the upper water neck I made a few years ago. I have plans to make a roller type tubing bender for smaller tubing, but I just didnt have time yet and watned this back together. So I made my own crimping beader out of an old pair of vise grips. Not a perfect bead but enough to keep the hose from popping off (not that it ever did before, but certainly cant hurt)
Heat shield standoffs:
A couple motor pics, with everything pretty much installed. The engine and gauge harness is in there too
Complete Engine and gauges harness:
Looks like I may be able to start setting up MS, checking sensors etc, on tuesday
That pretty much brings this years mess up to sunday night.
More to come. I'll try to update this regularly now.
Dan
YEP, my 60' times suck
247HP/267ftlbs at 13psi with built motor
Project updates and stuff: www.clubhousecustoms.com
email: dan@clubhousecustoms.com
Re: what I have been up to.... 2.2OHV content inside :eek:
Thursday, April 10, 2008 12:46 PM
noice man !. looks like am onster !
My Cav
I give up...
Thursday, April 10, 2008 1:01 PM
Think you'll hit 300 hp with that beast? You certainly aren't cutting any corners. Good luck with the rest of the build man! I'm sure its going to be a blast to drive!
Edited 1 time(s). Last edited Thursday, April 10, 2008 1:01 PM
Thursday, April 10, 2008 1:13 PM
Ill easily hit 300hp with this. I made 247/267 on 13psi with a smaller exhaust, turbo and cam.
I dont see any reason why 350 or more isnt possible on pump gas and meth . And I am talking wheel hp.
Dan
Thursday, April 10, 2008 1:15 PM
Stupid slow show car
Thursday, April 10, 2008 1:21 PM
Damn I had never seen your car before. The paint looks amazing! I take it you had the engine bay painted too?
I know I have said alot of negative things about the 2.2ohv. It does not realy matter what I think of the original engine in your car. It is far from stock. The quality and sheer amount of work that has gone into your car is amazing. Evrything done looks professional and not half assed.
What you have done demands respect! You should be very proud of what you have done even despite those like myself have who have said many discouraging things.
I like what you did with the vise grips. That is a new trick I never thought of.
I look forward to seeing the progress.
Thursday, April 10, 2008 1:27 PM
OHV notec wrote:Stupid slow show car
I think it needs to move even to be a show car. haha
Ill accept jack stand king for now.
Dan
Thursday, April 10, 2008 2:14 PM
...and your in rochester NY??
How come we've never crossed paths before? Fuggin monster right there.
Thursday, April 10, 2008 2:20 PM
[Wipes drool from mouth!!!]
Atleast one of us OHVers gets to live out our dreams of the ultimate LN2!
Thursday, April 10, 2008 2:44 PM
Cody@RD Fabs wrote:...and your in rochester NY??
Probably cuz I dont get out much. I talk to someone there occasionally... not sure on the real name.... eh..... ask around lol
Dan
Thursday, April 10, 2008 3:55 PM
you have been voted one of my heroes! this is the most badass build of all time on the org of an LN2 that i have ever seen. you sir are a god!
Thursday, April 10, 2008 5:19 PM
dear LORD the amount of custom fabbing and detail work is AMAZING on this build.
i want more!!!
Thursday, April 10, 2008 5:32 PM
Just click on the ClubHouseCustoms.com Link and click on his JUICEDZ4 tab or on of his other projects. The link is also in Dan's (JuicedZ4's) signature.
Thursday, April 10, 2008 5:45 PM
WOW, that thing looks PRETTY and MEAN at the same time haha.. Nice job man.
Thursday, April 10, 2008 6:10 PM
Very nice...I really like the work on the intercooler and radiator.
Thursday, April 10, 2008 7:35 PM
this needs posted in photos n media!
Thursday, April 10, 2008 9:12 PM
Holy crap! That thing better haul ass!
Thursday, April 10, 2008 9:42 PM
Awesome! That vice grip thing is cool, too. Gen 2 FTW!
2010 Honda Fit LX
Thursday, April 10, 2008 9:49 PM
my new role model
Today we plan for the future, tomorrow we make history.
Thursday, April 10, 2008 10:29 PM
OMG that car is simply amazing i was amazed at the amount of work and attention to detail i now have a new found respect for the LN2. Kudos
Thursday, April 10, 2008 10:30 PM
More done tonight.
FInally taped up the inside of the rad ducting with some heavy duty aluminum tape. Its almost like it was welded together now. Its lost any tinny sound and seems much stronger, plus it will keep it sealed up. I also got the foam on to seal it to the radiator and IC. Then I got the bumper support, oil tstat (yep its in the bumper), the coolant overflow tank, horn, and the bupmer cover sitting on. Its almost a car again!
Dan
Thursday, April 10, 2008 11:15 PM
I've said it before and I'll say it again, I love you work man! I can't wait until I've got my own house and a garage again so I can get back to doing real car work.
Can't wait for any and all updates. I'm not a thread subscriber, but this is definitely bookmarked.
I love the project too, my roomie and I are swapping his 91 tbi 2.2 Beretta over to a 94 mpfi head and injection and then eventually going to boost it thereafter. We've got 95% of the parts, I'm just waiting on him to be ready to tear into it. I've always been a 2.2 fan, especially ones that are quick.
Thursday, April 10, 2008 11:29 PM
Damn, nice duct work! It looks way beeter that what a friend & I fabbed outta a poly-vinyl wastebasket for a scoop to fed the IC on his '87 GN. Ours was quite functional in increasing airflow to the IC, and helped it run quicker times, but yours looks alot better & will probably be just as effective if not more.
Go beyond the "bolt-on".
Friday, April 11, 2008 1:07 AM
Dan is the OHV God of Fabrication as far as I'm concerned.... those of you just tuning in, go look up his previous posts about the motor build........ drooooooollllsssss....
Arrival Blue 04 LS Sport
Eco
Turbo
Megasquirt
Friday, April 11, 2008 6:44 AM
one thing im having a hard time grasping....
how is the radiator going to get any air with it blocked off like that?
