For a while now i have been looking for a 02 simulator. After Profile surfing for a while ive seen that there is quite a few guys around here using the 02 emulator from zz performance. I Was wondering if it will work for my 03 ecotec cav because i cut out the cat converter and up to now have just been dealing with the CEL. Now i know that i could go get a an 02 bung and some anti foulers and put my stock secondary 02 sensor back in and that might work but. Let me remind you until i get the money for a high flow i will have no cat at all. Blah blah illegal.... i know....... im saving up the money give me a break. And also i dont really have access to a welder unless someone from here wants to be nice and help me out =). I Could pay someone on here a little bit to weld for me. As long as they live close to ohio. But, I would like to just be able to pop this thing into secondary 02 connector and not worry about it so i just wanted to ask you guys first before i bought the thing and it ends up not working. Right now the emulator is out of stock but im ordering the second they get them in stock again.
Heres the link if any of you guys want to look at it.
http://www.zzperformance.com/grand_prix/products1.php?id=834&catid=107
So just tell me if you think it will work or not thanks =)
CarDomain http://www.cardomain.com/id/TMald123
i would think it would be easier with the anti fouler  plugs... then again i dont have to worry about a second O2 sensor
 mine never came with one
1997 Cavalier Z24 - 15.647 @ 88.02 MPH
No idea if it'll work on the Eco, but I've used the ZZ sim on 2 of my 2.4l's.
Call regarding stock, I just ordered one 2 days ago for my beater which was throwing a CEL and is missing the second 02.
Personally though I'd just have the "test pipe" welded in with a bung and do the anti-fouler trick.  After shipping you're spending $50 on a sim, which could be spent at the exhaust shop just as well.
Most exhaust shps will weld in a O2 bung for you for about $5-$10. At most the anti-fouler sim will cost you $10, so you are looking at $15-$20, if you can not afford this at one time you should not be modding your car.
John Higgins wrote:Most exhaust shpos will weld in a O2 bung for you for about $5-$10. At most the anti-fouler sim will cost you $10, so you are looking at $15-$20, if you can not afford this at one time you should not be modding your car.
Well seeing that this is going to cost me 40 dollars i think that i have MORE THAN ENOUGH MONEY to do it. I just needed to know if it works with ecotec cavaliers.  I will be taking the welding class at my school soon enough. If this dose not work i will just wait till then.
or find a friend with HP tuners and turn it off.
but zz performance ones i am sure will work.  call them.
anti fouler trick aint too bad to do either.
