So i am looking into fuel pumps..i been reading bout the in line pumps..i checked walbros website but is there any information on an actuall In Tank 255 pump? At higher rpms i am having a fuel issue and i am looking for a pump but im kinda lost where to go. any help would be appreciated
thanks in advance
kyle
what makes you think its a fuel issue?
External or internal pumps will both work fine. I ran a 255 Walbro last year and I'm running an MSD external this year. What type of info are you looking for?
i know its a fuel issue cause i was there when we were tuning the car on the dyno with hp-tuners.. i'm seeing a lot of people run the external pump but then u have to modify the stock pump to make it accommodate( spelling) for the in line pump..i'm just looking for some info on the best pump to use and the easiest one to use..i want to do do this right the first time so i don't have to re-correct my self in the long run if ya know what i mean
you dont do anything to the stock pump when using an inline. wiht the MSD, you have to mount it below the gas tank (which is almost impossible) or throw a switch on it so the factory pump primes the line before the MSD starts running.
