Eco swap wiring questions - Performance Forum
Friday, May 02, 2008 3:06 PM
I found a 1999 Sunfire for a cheap price, and the car is clean. I know when you do an eco swap finding a donor car is best as you need all the wiring from it. Well my question is will I need all the wiring from a 2003 up sunfire, or will I be able to use the wiring from a 2000 model, since people are swapping ecotecs into those? They have 2 Sunfires and 3 Cavaliers that are 2000-2002 models at my local salvage yard and none of them have been touched. Any help is needed and appreciated!
Re: Eco swap wiring questions
Friday, May 02, 2008 3:13 PM
Well you will need the body wiring harness (can be any 00+ sunfire for the body harness). You will need the fuel tank (any 00+ tank will work). I have heard some 99's had the plastic tank if your 99 is then great your lucky. You will need a dash harness (any 00+ will work). When it comes to the motor, engine harness, BCM and ECU, and radiator it needs to be a Ecotec car they came from. It is best if you grab the ECU, BCM, cluster, and ignition switch all from the same car.
Friday, May 02, 2008 3:42 PM
Thanks there John, you just made my freaking day! I'm buying the chassis harness off of one of these vehicles. I luck out, as he's only going to charge me $75 for the harness. I might buy all 5 harnesses, never know if there will be a ground someday. lol
Friday, May 02, 2008 4:11 PM
John Higgins wrote:Well you will need the body wiring harness (can be any 00+ sunfire for the body harness). You will need the fuel tank (any 00+ tank will work). I have heard some 99's had the plastic tank if your 99 is then great your lucky. You will need a dash harness (any 00+ will work). When it comes to the motor, engine harness, BCM and ECU, and radiator it needs to be a Ecotec car they came from. It is best if you grab the ECU, BCM, cluster, and ignition switch all from the same car.
I couldn't have said it any better.
