The OBX pulley is a cheap knock off of the Unorthadox crank pulley. There is a reason why the Unorthadox pulley costs a hell of a lot more than the OBX crank. People have used the BOM with little side effects. Watch for wear here....as seen in the picture. Especially on non hard coated aluminum or cheap aluminum pulleys. Also you might want to change your seal if it is old.
what size of belt do you need when you take the a/c off?
adan diaz wrote:what size of belt do you need when you take the a/c off?
What engine, what car, what anything. FILL OUT YOUR PROFILE.
