i was browsing the net a little bit ago for a new exhaust for my d.d. (do to the exhaust rusting from the down pipe back) and came across this
clicky does anyone know how much of a difference there is in the ln2 and the ld9 exhaust from the cat back and if this would be bolt up or if it would need any modification. keep in mind this is for my d.d. and its for a quick fix
. thanks
hondas are like tampons.....every pu$$y needs one...
mildly built 99' ln2, eagle h-beam rods, wiseco forged alum. pistons, cusco oil catch, t3/t4 super 60 garret, tial 40 mm wastegate, hp tuners, prothane mount inserts, 2.5" exhaust.
all 3rd gen exhausts are the same. but the mounting brackets might be different in the later years
ok thats what i figured, at first i thought that the convertor was more up-stream on the ld9 than the convertor on the ln2, i guess i can just buy it and try it out and if it dont fit ill throw it on my z24. I appreciate the help though, thanks.
