Stage 1 Comp Cams install - Performance Forum
Sunday, May 18, 2008 10:53 AM
How difficult is it to install new cams? Im saving up for the stage 1's right now and i just need to be prepared. If i need to take a day off work or anything.
"You can only feed them semen for so long before their legs fall off."
Re: Stage 1 Comp Cams install
Sunday, May 18, 2008 11:11 AM
find the Kent-Moore camshaft install tool. it'll make your life much easier. also, the bolts holding the timing chain sprockets to the cams are torque-to-yield, meaning one-time use only. some people have had luck reusing them. I bought new ones. you'll need a torque wrench and a torque angle meter as well. make sure cylinder #1 is at TDC. get a bottle of Comp Cam lube.
it's not really difficult if you have the instructions and the right tools.
Desert Tuners
Sunday, May 18, 2008 11:21 AM
What would you estimate install time at? On average.
Sunday, May 18, 2008 11:36 AM
if everything goes correctly, and the motor is in the car... 2-3 hours.
Desert Tuners
Sunday, May 18, 2008 12:25 PM
And thats with the cam tool. Without, your looking at like 1 full day, or more.
Tuesday, May 20, 2008 12:02 PM
Does anybody have a link for this tool?
