Its a work in progress... but last night i jumped on the dyno in halifax and after 5 pulls made 370whp and 310wtq. Waiting to instal the rest of my meth kit and try again.
Using Hp tuners and likeing the results. The forms on this site have been a HUGE part in the tuning process . For that i say Thank U!!!!
Hopefully more good updaes to come!!!!
491whp, 393wtq
11.93@ 127mph
Raven Autosports (902)850-3330
nice numbers but meth is bad
thats some nice power, bet your happy with that haha
soon to be supercharged, eibach sportlines, KYB AGX struts, 18" RTX poisons
(Sigh) If only all that power were properly directed (RWD!).
Go beyond the "bolt-on".
Nice, we need a few more eco's at this power level or greater to catch up with the LD9 guys
So are you still adjusting the fueling? The AFR seems to be all over the place, although it also stays at a safe range for the entire pull (>12:1). You may be able to pull more area under the curve just by flattening out the fueling.
I see from your profile that your running a GT35R - I'm guessing your plans are higher than 370whp?
How is meth bad. not only is it a great way to cool things down, but it cleans the @!#$ out of your internals. spray meth consitanly for a couple of weeks then pull you manifold. that @!#$ will be clean.
you have any specs on the run lbs, ign timing, anything you can give us. Im interested to see how much a meth kit would help. along with how they corlate to those big numbers.
good #'s man
boobs now with Riboflabin"
wOOT wOOT Way to rock out with your.... Mad props.
Is there any way you can make it to the bash? I as well as many others will want to see this in person. But to tide us over for now could you post some pics of your setup?
Wow, nice numbers... Lets see pics of the engine bay
2012 numbers - 4SPD
AUTOMATIC!!
Jcavi wrote:you have any specs on the run lbs, ign timing, anything you can give us. Im interested to see how much a meth kit would help. along with how they corlate to those big numbers.
good #'s man
This is the first time we have used HPtuners so not bad for a first timer
The A/F does need some work and it will come with time. That pull was at 20psi, ignition timing is anywhere between 19 degrees in the low end of things and 15 degrees up top. We are still seeing .2 - .5 of knock above 6600rpm. WIth meth we should be able to get rid of that and add some more in as well. I would really like to see this car make 400+whp on 20psi. Going to try to get the meth kit up and running this weekend and go from there.
Congrats Andy...car works awesome!
Quoth the Raven 'Nevermore
raven@accesswave.ca
Raven Autosports
55 McQuade Lake Cres,
Halifax, Nova Scotia, Canada
(902) 850-3330
10.82@132
Here are some pics
491whp, 393wtq
11.93@ 127mph
Gooodness, I thought my GT30 was big,,, thanks for the pics man.. Nice overall car you got goin on..
very nice numbers, now lets see some new ones at the where you should be at.
Riddle me this... riddle me that...
nice #s and freaking awesome looking turbo manifold
Nice #'s. I hope you meet you goals.
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
schweet! watch out LD9 guys, im sure he's got more in it
All show, coming soon ---> GO
foshizzle !
. Aesome @!#$
My Cav
I give up...
Its a awesome car but I think you should be making a lot more then what you are now without the meth. Im going with this same kind of setup but i'm going to push it a lot harder. Overall nice job push it a lil harder please.!.
______________________________________________________________________________________________
~Using nitrous is like having sex with a hot chick with an STD, you wanna hit it, but your afraid of the consequences.~
Mike wrote:Its a awesome car but I think you should be making a lot more then what you are now without the meth. Im going with this same kind of setup but i'm going to push it a lot harder. Overall nice job push it a lil harder please.!.
The block is not sleved so pushing it much further would be a little risky IMO. He will be getting a Bates race block next year then he can push it to the limits.
raven@accesswave.ca
Raven Autosports
(902) 850-3330
10.82@132
Nice work guys, can't wait for more numbers. They will tell the true tale.
Nice car man, those are wicked numbers. I can't belive you're from halifax and i've never seen the car around, i'm from dartmouth. i was going through your specs and stuff, and was wondering are you using HPT to tune?
2003 White Cavalier LS Sport Coupe
Stitch wrote:Nice car man, those are wicked numbers. I can't belive you're from halifax and i've never seen the car around, i'm from dartmouth. i was going through your specs and stuff, and was wondering are you using HPT to tune?
Actually im from the valley but do alot of work out of Raven's shop so im in the city all the time. And yes im using HPT. If the meth is in on sat we will be back on the dyno wed night. We set up in Burnside if u wanna cheak it out . Its behind some ventlation or A/c fabraction building across the road from preinces auto...(my spelling sucks...lol)
Drop in , say hi.....be there any time after 6pm.
491whp, 393wtq
11.93@ 127mph
this car is rediculous / retarded fast amazing work, congradulations on the numbers.
last year when you loaned it to greg when you went away he took me for a drive as im looking into an eco swap in my 02' however im looking at goind the S/C route but the turbo tore my asshairs out
i seriously could not believe the balls this car had. ive driven some quick cars but none that had the overall feeling of raw power, IN A J!, so again congats Mr. Misner
UNDREDAWG...? wrote:Stitch wrote:Nice car man, those are wicked numbers. I can't belive you're from halifax and i've never seen the car around, i'm from dartmouth. i was going through your specs and stuff, and was wondering are you using HPT to tune?
Raven is from NS too!?!?!?!? mann i didn't know that. i'm gonna be in for SURE. I'm just waiting to find a place to get my downpipe made and i'm gonna turbo my eco, i've been waiting forever to get all my parts. lol.
