all sunfires 3 bolt flange behind cat? - Performance Forum
Monday, June 16, 2008 7:18 PM
i have a 2000 sunfire se and am looking at doing a custom exhaust, do all years sunfires have a 3 bolt flange behind the cat? any help greatly apreciated, thxs in advance
Re: all sunfires 3 bolt flange behind cat?
Monday, June 16, 2008 8:33 PM
all cavy's and sunfires have the three bolt flange thru all the years....so basically all catbacks are interchangeable. For example, my exhaust came off an 03 eco cavy and now its on my 00 LN2 sunfire...
Monday, June 16, 2008 10:13 PM
99-05 catback are all the same , other than chrome tips , or the dual systems used by the sunfires
95-98 2.3 and 2.4 , are the same length as above , but different hanger locations , the 95-98 2.2 are like the 95-98 for hanger locations , but the length is different
Tuesday, June 17, 2008 7:01 AM
Why not get a header and new cat and do the whole exhaust?
Tuesday, June 17, 2008 7:42 AM
well thats kind of what im thinking too, but by installing a header and cat is it all going to be slip fit style that i can weld or bolt flanges in there too? im thinking about using a gt dual exhaust as a template for my bends as well, has anyone used the band clamp style instead of the u bolt style to hold everything together versus welding? most exhaust on big rigs(which ive worked on quite extensivly uses that style of clamps, im thinking id rather have it so i can take it apart with little difficulty in case i need to make changes
Tuesday, June 17, 2008 11:25 AM
band clamps are better...or atleast that is what I have been told...tho welds are the best for making a near leak proof system. But yes if you feel the need to make changes (ie add in resonator cuz its too loud) then use band clamps (if possible) until you have built what you want.
Tuesday, June 17, 2008 12:00 PM
so if i use a 96-98 dual exhaust off of a 2.4 as a template for my bends after the axle they should be the same? im thinking maybe 2 1/4 to the rear axle then stock dual from the y pipe back
Tuesday, June 17, 2008 4:02 PM
yes they should be the same...though I don't advise going from 2 1/4 to the stock 1 7/8 pipe size....might as well just keep going with 2 1/4 from the y pipe on and buy some dynomax super turbo mufflers to keep it quiet...throw in a resonator that is around 20" or longer and you will be set...something with a nice growl but definitely not ear shattering, just a mellow tone.
Tuesday, June 17, 2008 5:08 PM
reason why i figured on necking down to stock dual size was id use a stock rear pipe and ive read alot of debate on here about exhaust and having too much exhaust and equal flow through the pipes , i also figured on a resonator, not sure what type yet, maybe just a glasspack type the same style as a thrush or cherry bomb . I dont want to go crazy with the exhaust because the most i will do on the motor end is swapping a 2.8 with some very mild mods , thats why im holding off on the header and cat , kind of a gradual build while running it as a daily driver.as for the reason of going duals, its to balance out the rear look/sound , and i need to replace my rear exhaust anyway as the stock factory muffler and rear pipe are going, as for mufflers im leaning towards the dynomax super turbos or magnaflows
Tuesday, June 17, 2008 6:29 PM
from what I have read, being consistent on pipe size is the best result. Hence why I think you would create a nasty bottle neck at that y-pipe if u kept it at the stock diameter. Plus, any aftermarket muffler is going to have a larger diameter than the 1 7/8 (stock pipe size) hence why its easier to just stick with 2 1/4 all the way back to a nice magnaflow oval muffler. But I am biased with my 4"x9" oval magnaflow and 22" long 4" round magnaflow resonator. You could also go the route of using a camaro style muffler that has one inlet and two outlets....
Tuesday, June 17, 2008 6:54 PM
id love to do a full out custom exhaust with all tubing bent from scratch but custom bending in my area isnt realy an option , just to bend the pipe which i explained using the sunfire gt dual exhaust as a template but going with larger pipe from the places i called it was anywhere from 700-1000 just for the pipe and bending to go from the cat to the mufflers, not including any other parts,a couple even said it couldnt be done which is why i figured id keep the custom bends to a minimum and when i get around to swapping in a 2.4 with a pacestter header and cat the tubing bends are very minor as oposed to behind the cat. I can get a new stock gt complete dual cat back for a 98sunfire(resonator included, minus mufflers) for 160, buy a pair of mufflers, fab up some hangers(able to weld) and install myself.
Tuesday, June 17, 2008 7:11 PM
the mufflers ive been debating on are borla 40651 ,magnaflow 11124 or dynomax 17762
Tuesday, June 17, 2008 7:19 PM
borla is expensve from what I have heard. Both the magnaflow and your dynomax choices are decent, tho you are picking smaller sized mufflers which means your gonna need a big resonator or you will find its too loud. My suggestion is to go with a larger overall muffler. The super turbo will be a quieter muffler than the magnaflow but will still require atleast an 18" long resonator, the longer the resonator the better usually. They arent expensive either, especially if u buy a glasspack, cherry bomb or thrush...personally i still think you should do 2 1/4 all the way back but thats my opinion...
Tuesday, June 17, 2008 7:35 PM
thxs alot for all the comments scott, uve been a great help and made me think things over, the pipe has a stock resonator but i was thinking of cutting it out and replacing it with a cherry bomb or thrush. im wondering if magnaflow sells the rear dual pipes and not just a complete kit........
Wednesday, June 18, 2008 4:33 AM
stock resonator means nothing, like I said before you will need one that is atleast 18" long....so if u use a cherry bomb or thrush atleast that long it should be alright and won't drone you out down the highway. As for magnaflow...they only sell mufflers/resonators/cats or complete catback systems, they don't just sell pipes....unfortunately, I don't remember where a good place to buy custom pipes on the net is anymore (I read about it once). So if you don't feel like bending pipe yourself, I am sure if you use the search button or make a post asking about where to get custom bent pipes you will find your answer. If I remember correctly, there is a company called Custom Tubes that sells good piping. Hope that helps!
Saturday, June 21, 2008 7:00 PM
will a aftermarket catback exhaust system meant for a 2004 Cavalier Z24 fit my 1996 cavalier 2.4L?
thanks.
~1996 Cavalier LS 2.4L (auto)
Saturday, June 21, 2008 7:12 PM
yes
