quick tricks - Performance Forum
quick tricks
Tuesday, July 15, 2008 1:26 PM
Hi I am lookin for some quick tricks to help with my 95 sunfire dohc 2.2 anything that does nt cost me any money is great. thanks
Re: quick tricks
Tuesday, July 15, 2008 1:53 PM
http://www.j-body.org/forums/read.php?f=2&i=215434&t=215434
you'll probably want to read that. there aren't really any quick tricks that are free. sorry.
and your sunfire either came with a 2.3 DOHC or a 2.2 OHV.
the only dohc 2.2 is the ecotec, and that motor never came in a 95.
Re: quick tricks
Tuesday, July 15, 2008 1:56 PM
thanks i still dont know everything bout this car any help i can get is great
Re: quick tricks
Tuesday, July 15, 2008 1:59 PM
and im not tryin to get more power just try to get more mpg
Re: quick tricks
Tuesday, July 15, 2008 2:03 PM
check air pressure in your tires, dont go over the speed limit, and dont be heavy with the gas pedal....those are your free gas milage improvers.....i am sure theres a few similar to add on too...
Re: quick tricks
Tuesday, July 15, 2008 2:05 PM
full tune up, oil and filter change, new fuel filter, air filter, a little extra air in the tires, take anything out of the car you dont need, and dont use the a/c.
Re: quick tricks
Tuesday, July 15, 2008 3:13 PM
Re: quick tricks
Tuesday, July 15, 2008 4:05 PM
I'd add something, but I think you best bet as to what-to-do is this: Use "Search".
Go beyond the "bolt-on".
Re: quick tricks
Tuesday, July 15, 2008 6:07 PM
Chef Dug wrote:A/C MYTH
yeah, thats nice. i can consistantly get 50 miles more out of my tank with the windows down not using the a/c. please, try again with REAL proof.
Re: quick tricks
Tuesday, July 15, 2008 6:40 PM
Not to mention performance from not using a/c...
Re: quick tricks
Tuesday, July 15, 2008 7:10 PM
Performance mods can increase gas mileage as the engine is just a large air pump and the easier it is to get air in and out of the motor, the less fuel is used.
The problem is, with performance mods, you also increase the ability to use more fuel.
If you drive like a granny with lots of bolt ons, you will see fuel savings.
It is too tempting to use the new toys and the mileage is usually worse.
2003 Sunfire with 2 1/4 inch turbo muffler, 2 1/4 piping, 2 1/2 inch resonator, a 2 1/4 inch catalytic converter, 2 1/4 inch down-pipe, a ported LSJ manifold, E-bay strut brace, and an AEM true cold air intake NOPI edition.
Re: quick tricks
Tuesday, July 15, 2008 11:03 PM
^So true... Sotrue.
Re: quick tricks
Wednesday, July 16, 2008 5:18 PM
very true but i dont dog it unless im late for something or someone wants to go other then that i drive like a granny and it pisses my wife off
Re: quick tricks
Wednesday, July 16, 2008 5:20 PM
also im lookin for any bolt on part i just didnt know if there was any tricks i could do
Re: quick tricks
Wednesday, July 16, 2008 5:24 PM
intake
Re: quick tricks
Wednesday, July 16, 2008 6:02 PM
Free tricks that you can do would be get the dremil or drill with stone bit and do your own porting.
Get the exhaust manifold, and intake manifold off and start removing all the extra casting and smooth them out.
Match porting is also a good thing to do if you want to go the extra mile.
You can go to home depot and use the pvc pipe to make a ram air unit like I did for my Daytona.
It works good, but I cannot tell you if it was the fact I got cold air or if it was actual force of air giving me better performance. Not free, but it is cheap. Just route the piping to the stock airbox from under the car, use a drop in K&N too. You can also swap the baffled section of the intake with a smooth pipe to help flow.
Cut off the muffler? Maybe remove the baffles inside it?
Probably make your ears bleed for an extra 2hp though.
Re: quick tricks
Wednesday, July 16, 2008 8:22 PM
the pvc pipe on the intake is kind of a bad idea, it will release toxic fumes when it is subjected to the heat under the hood. but thats my two cents.
When in doupt, grub.
Re: quick tricks
Wednesday, July 16, 2008 9:30 PM
I had the pvc ram air on my Daytona for years.
If there was fumes, I did not smell any.
It probably all went under the car and away.
Some fumes probably went into the intake, but the car seemed to like it.
Re: quick tricks
Thursday, July 17, 2008 12:01 AM
Mike85220 brings-up a good point about air-inlet mods: If you modify it to breathe easier (Better filter & what-not), doesn't it make sense to make sure the filter gets all the air it can breathe as the car goes down the road? In short: Scoop it! If it's located in front of the driver's front-wheel but behind the fascia panel, build a sizeable scoop to go in that corner of the fascia that faces forward to collect the head-wind the car will see as it goes down the road & an air-box around the filter that traps & collects the air around the filter. Is it under-hood with a short-ram? Build a box that will do the same & seal against the hood when it's closed beneath (again) a sizeable scoop that faces forward to collect the head-wind as the car goes down the road. It makes a difference, and any data-logging that you do with it in place will prove it. BTW Mike, where did you locate the collector-point of your PVC FAI (Fresh-Air Intake) system (The part where it takes air in)? And how?
