Valvetrain upgrades..... - Performance Forum
Tuesday, August 12, 2008 10:46 AM
What exactly should i upgrade in my valvetrain to be able to rev to 7k? Obviously i need camshafts that put the powerband up there but do i need to upgrade the valvesprings and to what ones? I dont wanna go any higher than that and im turbocharging my car this winter and ditching the supercharger and i wanted a higher powerband. I have access to hp tuners so changing the spark rampout and limiter is not a problem. Thanks...
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
Re: Valvetrain upgrades.....
Tuesday, August 12, 2008 11:43 PM
Publikdstrbnce wrote:. I have access to hp tuners so changing the spark rampout and limiter is not a problem. Thanks...
i hope you bought your own.
Wednesday, August 13, 2008 8:56 AM
i hope you know if you keep getting smart with me im gonna kick your ass. and yes i bought my own you little ungrateful prick
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
Wednesday, August 13, 2008 9:21 AM
Springs by ferrea should do the trick.
If you get the comp cams and the Ferrea valve train PM us we will get you the hookup.
-Aaron
www.TurboTechRacing.com
Wednesday, August 13, 2008 9:29 AM
I have heard of people running up to 7,000 RPM with stock 2.4l springs and no problems I think it might have been skillz?
I know i have been running 2.3 HO springs for the past two year with no problems they are a lil stiffer spring. + the HO springs are about $60 at napa. but you also need the retainers they where right around $40 when i last bought them.
I would think to stock springs are fine up to 7 if that's all your going for I haven't really heard of any valve float on a quad.
Wednesday, August 13, 2008 11:02 AM
im going to set my rev limiter to 7k so i cant rev over that. i want a nice set of cams and springs. im going with the t3 super 60 so i dunno what cams i should get... any advise?
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
Wednesday, August 13, 2008 11:10 AM
Publikdstrbnce wrote:im going to set my rev limiter to 7k so i cant rev over that. i want a nice set of cams and springs. im going with the t3 super 60 so i dunno what cams i should get... any advise?
comp cams turbo grind games but in your case i would recommend maybe HO cams ????
Wednesday, August 13, 2008 2:48 PM
Paul Tjepkes (N/A MADNESS) wrote:I have heard of people running up to 7,000 RPM with stock 2.4l springs and no problems I think it might have been skillz?
7,000 rpm should be fine with stock springs. 7,600 rpm on stock springs is not recommended, take my word on this one....
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
Wednesday, August 13, 2008 7:55 PM
Yep, what he said. I have been shifting @ 7k on occasion on the street and more often at the track. At least for my dyno @ 6psi on stock cams, my peak power was 5600 rpm's so I am going to lower mine until I change the cams
Jason
99 Z24 Supercharged
157hp/171tq - NA
190hp/170tq @ 6psi
LD9 for Life
