L.O. manifold gone wrong, need help ASAP - Performance Forum
Tuesday, August 19, 2008 9:38 PM
Sorry if you guys helped someone before for this but I am not sure what went wrong with the swap, I used the 2.3 manifold gasket, L.O. manifold(cracked it but fixed with some hi-temp metal(some liquid stuff at Canadian tire), I used the MAP sensor from the quad, and left the sensors that were on the throttle body on and plugged my wires into it, But every time I try to start it the RPMs instantly rocket up to 6,000rpm, and thats without touching the gas peddle, I used the 2.3 throttle body, and throttle body cable bracket, I didn't install the cruise control yet, What did I do wrong? I really need the car up and running by Thursday(very important), any help would be VERY MUCH appreciated. ]
I'm sure those pics may help
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my ride." -Amen
Re: L.O. manifold gone wrong, need help ASAP
Tuesday, August 19, 2008 11:54 PM
Are there any vacuum leaks? like, are all the holes filled in on the intake manifold? And if so, how is the tension on the throttle wheel/cable?
I'm back from the dead.
Currently Driving: RSX Type-S.
My Cavalier Burnt up :-(
Wednesday, August 20, 2008 2:10 AM
I would recommend not having the air oil separator hose connected where you have it. Remove the hose from that port and cap the port off, see if that fixes it.
Wednesday, August 20, 2008 3:14 AM
Also, I thought you were to use all your 2.4 sensors...., but it has been YEARS since I had an LO on my car.
Wednesday, August 20, 2008 4:46 AM
yea...im pretty sure he was supposed to use all 2.4 sensors...but if the idle is really shooting up that high it very well could be a large vavuum leak
Wednesday, August 20, 2008 5:17 AM
whats the chances my header could not be torqued to spec?
Wednesday, August 20, 2008 5:27 AM
"-Install the IAC and TPS sensors on the throttle body (make sure you use the right sensors 2.3L sensors for 2.3L TB and 2.4L sensors for 2.4L TB), be extremely careful with the bolts because they will break if over tightened." that was taken from the HO Swap guide
Wednesday, August 20, 2008 5:30 AM
isn't there a port on the back of the manifold that needs to be blocked off?
I would use the map sensor from the LD9, use the TPS from the quad, maybe the air bypass valve is bad and needs to be replaced, that sensor lookin thing in this pic, at the top of the TB
definitely a vacuum leak if that isn't the issue. Where did you crack the mani, maybe when you "fixed" it, it wasn't done well enough. Especially if it was done on the side that sits up against the head.
Wednesday, August 20, 2008 5:53 AM
sounds like a vacuum problem to me.,....
does idle go back down after the initial 6k starting rpm, or does it stay there?
It COULD be the IAC, but I would lean towards a large vacuum leak first.
Make sure there are no open ports on the mani, and make sure it is making good contact with the head.
Wednesday, August 20, 2008 6:01 AM
thats the patch job I did for the intake manifold. like I said I used the liquid hi-temp metal to do it
Wednesday, August 20, 2008 6:22 AM
and Will there isnt that much slack everything is set up and looks like its suppose to, so I rule out the throttlebody on this one I too believed there was a leak but didnt have idea where to start looking
Wednesday, August 20, 2008 6:35 AM
and are you guys talking about the one is this picture?
http://farm4.static.flickr.com/3108/2781434350_be9cc47697.jpg?v=0
what would I need to block that off? but for some reason Im leaning towards the mating surface
Wednesday, August 20, 2008 11:45 AM
http://farm4.static.flickr.com/3003/2780562682_28a1779953.jpg[/imim not familiar with the LO but what is that open hole on the top of the picture? it looks like a sensor should go there? is that a hole?
dont take this the wrong way, but.......why do all this work for a manifold that is cracked?
Wednesday, August 20, 2008 11:46 AM
Wednesday, August 20, 2008 12:00 PM
The two bolts on the side of the trans case that hold the ground... did you swap them around? I forgot to do that on my 99 Cav when I did this swap a long time ago... the bottom edge of the manifold wasn't even touching the head. The stud with the ground wire and nut on it was in the way... once I switched them (bolt to the top, stud w/ nut to the bottom) I had the clearance I needed.
Wednesday, August 20, 2008 8:04 PM
^^^^ what John said but there is no doubt about it you have a leak a very large leak.
Wednesday, August 20, 2008 8:31 PM
I just went out and redid it all with new manifold and tried what you told me John but now Im not even getting a ticking from the starter
Thursday, August 21, 2008 9:07 AM
sounds like you didnt get all the grounds reconnected.....
Thursday, August 21, 2008 9:16 AM
ya thats what I was thinking cause the upper bolt had 2 wires in a loom, and then a nut, then a ground wire, and the bottom bolt only had the one, and I kept the 2 on the top bolt but when I swapped then I put the ground that was attached on the bottom bolt thinking that should be enough of a ground do you think if I left the bolts swapped and just have the 3 on the top that my ground problem should be taken care of cause the car does run when you push and pop the clutch so its just a matter of getting my starter to work again. And you can notice the bottom end torque isn't as strong but over 3,000 is great. glad I didn't go to the H.O., and I stayed with the 2.3 MAP sensor for the drive and it worked just fine using all 2.3 sensors.
Thursday, August 21, 2008 1:48 PM
Sounds like you missed the small black wire that goes to the starter recall relay (mounted on the front frame rail). That's assuming you've had the recall done... if not... IDK... something else
You don't need both bolts... you could chuck the top one and put all the grounds onto the bottom bolt... or stud... whatever you end up using.
...j
