eagle rods with what bearings? - Performance Forum
Monday, August 25, 2008 5:11 PM
alright since my motor is ticking, and i assume it needs a rod bearing, i might as well replace all four rods with a stronger setup, the problem is i cant find the rods for a 2.4, and i also cant find what bearings to use and where to get them anyone know? also the motor is just going to see close to stock power, will a good set of rods and bearings keep this motor reliable???? i ask this cause every 2.4 but this one that i have owned has thrown a rod or spun a rod bearing. what else should be done while the bottom end is open? and what else can i do to keep this motor from doing what the others have done?
Re: eagle rods with what bearings?
Monday, August 25, 2008 5:21 PM
Clevite77. You can get them pretty much anywhere... AutoZone, AAP, NAPA, eBay. Eagle rods you can find also on eBay, CarCustoms.net, etc.
Do the 2.3L oil pump swap and kiss your oiling issues goodbye.
2001 Olds Alero (LD9)
650 whp / 543 ft-lb
@turboalero
Monday, August 25, 2008 10:46 PM
i would have to get the rods balanced regardless of new or used correct? im not gonna install this myself as i dont have enough time to mess with it, would would the cost be around to do the rods and bearings? and the what would the cost of the 2.3 pump swap be? im looking at some threads on the oil pump swap, what what it run for a shop to do it for me. or well a ballpark figure?
Tuesday, August 26, 2008 6:56 AM
All engine builders should balance the rotating assembly whether or not new or used. Bearings aren't that expensive, $60 I think is what I paid. The shop cost depends on the shop, it varies. My engine will be fully assembled for $700. Not sure if you can replace the rods and bearings without taking apart the top end too..
But I got a set of Eagle rods for ya.
V
650 whp / 543 ft-lb
@turboalero
Tuesday, August 26, 2008 8:27 AM
are you sure your car spun a bearing?
ticking could mean a lifter, or even a fuel injector. rods normally go out because of the 2.4 oiling system... it sucks balls. the 2.3 pump swap would be a major upgrade. pistons are also a weak spot in the 2.4 bottom end, rods would outlast the pistons if it weren't for the oil pump.
if you're going for more power EVENTUALLY, then i would get new pistons while everything is opened up.
Tuesday, August 26, 2008 8:50 AM
We have a great price on them and keep them in stock... WWW.TurboTechRacing.com
-Aaron
www.TurboTechRacing.com
Tuesday, August 26, 2008 1:42 PM
if you ever need main bearings, get them from gm parts direct. waaaay cheaper than what clevite is selling theirs for..
12.33 @ 111.67 mph [Oct 2009]
327.6 WHP 333.6 WTQ [10.1 AFR]
Friday, August 29, 2008 12:43 PM
CCasper wrote:are you sure your car spun a bearing?
2.3 motor being the quad 4 right?
Friday, August 29, 2008 12:56 PM
Yep.
650 whp / 543 ft-lb
@turboalero
Friday, August 29, 2008 2:45 PM
no do a dry sump oil pump and kiss your oiling issues behind. the 2.3 oil system still blows rod bearings
Friday, August 29, 2008 2:48 PM
Maken Waves wrote:no do a dry sump oil pump and kiss your oiling issues behind. the 2.3 oil system still blows rod bearings[/quoted
dry oil pump....where would i find this....and how would i install
Friday, August 29, 2008 8:37 PM
Like this:
Profile:
http://www.j-body.org/members/turbotechracing/cars/1/
-Aaron
