exhaust - Performance Forum
exhaust
Monday, September 08, 2008 8:04 PM
i have a 04 cav with a 2.25 cat bak and im putting a hi-flow cat on what do i do with the o2 after the factory cat
Re: exhaust
Monday, September 08, 2008 8:44 PM
I'm running into the same problem soon, i was just about to post the same question.
Re: exhaust
Monday, September 08, 2008 10:07 PM
i have a full exhaust including a high flow cat. i didnt even touch the 02 sensor
FREE-DOM
Re: exhaust
Tuesday, September 09, 2008 10:14 AM
If anything, just buy some spark plug nonfoulers, make sure they are the same thread, machine one out, if necissary, to fit the O2. Install them together with the O2, and you will no longer have CELs for the secondary O2! I had this settup on my cat-less Sunfire, and never saw a CEL pop up, and it would pass emissions, if I ever lived in an area that did emissions.
I miss my Sunfire, I want it back!
MMMM, HIDs
You will be missed.
Re: exhaust
Tuesday, September 09, 2008 11:04 AM
what do you mean? you put it after the cat. Any muffler shop will weld a bung in for you
Re: exhaust
Tuesday, September 09, 2008 3:32 PM
you buy a magnaflow cat that has the bung pre-installed, go worry free from there
Re: exhaust
Tuesday, September 09, 2008 6:38 PM
The cat i got does not have a spot to put the O2 sensor in is possible to just cut out a hole and shove it in?
Re: exhaust
Tuesday, September 09, 2008 7:42 PM
drill a hole and weld a bolt that fits the thread pattern of the sensor over the hole and bang instant sensor location.
Re: exhaust
Wednesday, September 10, 2008 8:05 AM
Oh, I thought it was a question about getting rid of CELs, my bad.
MMMM, HIDs
You will be missed.
Re: exhaust
Wednesday, September 10, 2008 1:37 PM
you can get an exhaust shop to install a bung for you.....
Re: exhaust
Thursday, September 11, 2008 5:15 AM
Joel Steward wrote:The cat i got does not have a spot to put the O2 sensor in is possible to just cut out a hole and shove it in?
ummmmm.....NO
the O2 does not have to be in the cat. Take it to an exhaust shop.
end thread
