ss/sc injector depth??? - Performance Forum
Saturday, October 11, 2008 9:28 AM
how far into the head should the injectors sit? is there a minimum they have to be into the head on my 2.4L? i have them so that the o ring is just sealing into the hole. is that ok or should i slot the fuel rail some more and move them down more??
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
Re: ss/sc injector depth???
Saturday, October 11, 2008 9:45 AM
did you measure your stock injectors and compare that to the LSJ injector length then dremel out the bolt holes to reflect that exact difference?
that's what i plan on doing next week
2001 Olds Alero (LD9)
650 whp / 543 ft-lb
@turboalero
Saturday, October 11, 2008 10:15 AM
well im kinda limited to tools at my work seeing that we had a break in and some of my tools got stolen. i slotted the rail but its sitting on the mounting hole stud thing that comes off the head.
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
Saturday, October 11, 2008 3:40 PM
all you have to do is measure the difference in length, and slot the holes that much.
and dremel a bit out of the other side so it doesn't hit stuff, like so:
650 whp / 543 ft-lb
@turboalero
