For those of you looking to delete your A/C. - Performance Forum
Monday, October 20, 2008 8:07 AM
I keep seeing the "what size belt" threads and never really saw an actual answer.
Well I've spend the weekend trying belt sizes and finally got right size.
Its a 63.5" belt.
That runs through all the pulleys with out the A/C pump there.
The part number is 5050635 I believe.
Its $25ish dollars.
But thats alot cheaper then getting the by-pass pulley for the AC.
And if your really cheap, you could always slip the old belt in the box and return it..
<img src="http://www.majhost.com/gallery/HCAJosh/crap/shooshined.jpg">
- putting the pieces back together -
Re: For those of you looking to delete your A/C.
Monday, October 20, 2008 8:16 AM
ya 635k5 will work also but ya i never saw a thread where that was mentioned either, but obviously the 2.4 and eco will be different..
jason
Thursday, October 23, 2008 8:35 PM
Anybody got a part # for the belt with a stock pulley on an EcoTec?
Tuesday, October 28, 2008 3:45 PM
first its a compressor not pump. second on some cavalier engines u cannot by pass the compressor u need the delete pulley. and third why would you return it the box w/ and old belt. thats so rediculous. and ull be looking reidculous whedn they open the box to check cuz they know theres fools out there that try to pull @!#$ off like that and u getcaught infront of everybody. laaaaameeeee
Working on obtainting an M-Class license... ?? Hint: 2 wheels.
Tuesday, October 28, 2008 6:37 PM
Toronto Cavalier wrote:first its a compressor not pump. second on some cavalier engines u cannot by pass the compressor u need the delete pulley. and third why would you return it the box w/ and old belt. thats so rediculous. and ull be looking reidculous whedn they open the box to check cuz they know theres fools out there that try to pull @!#$ off like that and u getcaught infront of everybody. laaaaameeeee
Actually all 3 motors that came in the 3 gen's (actually 4) you can delete the A/C without a delete pulley.
Ecotec A/C delete belt is 345k5.
Tuesday, October 28, 2008 8:37 PM
so whats the advantage of by-passing the a/c. will it give you a few extra hp or..
Tuesday, October 28, 2008 10:58 PM
..or if your AC compressor squeals like a stuffed pig and you really don't have a need to replace it since your area of the country only gets 1 day, maybe 2, a year where its needed
Plus all that AC stuff is heavy
Wednesday, October 29, 2008 11:26 AM
Ridiculous like all of that gibberish you just typed?
Wednesday, October 29, 2008 7:36 PM
Here's the belt I'm using.
Here's how I routed the belt. It's not my engine but was my guide to do this. Thanks to quad4forums.com for this information.
Also, one size does not fit all.
I'm running underdrive crank pulley and underdrive alternator pulley which warranted me to use the belt above.
It's not hard buying the belt when you do. Just measure (approximately) the belt with string and take it to your local auto parts place.
They can measure it and from that, you can purchase 2 or three belt sizes, some above and some below the measurement you made.
Install the one that fits and bring back the ones that don't. It helps to tell the parts place that you'll be doing this.
Anyway, my take on all this.
Misnblu.com
Newbie member since 1999
Thank you Dave and JBO!
Wednesday, October 29, 2008 8:32 PM
any advice for deleting the ac compressor from the 2200? like possibly a good belt size (non eco/2.4)?
Any time, any where, Lets put it on the line and race thru the lights
Wednesday, October 29, 2008 8:49 PM
^^Go to the auto parts and get a belt for your year car w/ no AC. No odd-ball belt measurement needed.
Wednesday, October 29, 2008 9:34 PM
^^ no other pulley changes or modifications needed to make it work?
Wednesday, October 29, 2008 9:46 PM
Right, as long as you still have stock sized crank and alt pulleys... check the belt routing diagram on your radiator cover.
