Well im workin on both my j and dsm and both have massive amounts of carbon build up on the pistons, vavles and valve bowls also inside the ports. Whats a good chemical to soak the head in to lossen up all this build up and to clean out all the oil? I was told that a hot tanking job would eat away at the head since its alumin on the dsm. i was told that just for the pistons that are still in the block just brake or carb cleaner and a green scrub pad would be best.
I would just use some brake clean and a soft rag. that will get it off.
although there are probably more correct ways to get it done.
well what im truly worried about is that when i get the head back together and on the engine andstart it up that something would be stuck in the head on the oil( metal shavings, dust, rust) and end up destroying the engine. That and i'm worried about water or cleanin stuff ending up in the oil to and hydro lockin the engine.
Then disassemble the head first, then clean it. A buffet-style foil pan half-full of Sea-Foam should suffice as a good way to soak them for several hours. Just blow-dry the parts fully with compressed air after wiping them when they finish soaking. In fact, if you already have a well-sized compressor... Just get an 90*-angle die tool for it & a set of wire brushes to chuck-up into it, and use that to clean the carbon off all the surfaces you can reach with it. It'll be alot faster, and won't damage anything... Except maybe your hands if you're not careful.
Go beyond the "bolt-on".
kool i'll try that stuff then. The head is taken apart. Will the Purple Power stuff eat the carbon off? I dont have a air compressor. Is there any kind of cleanin stuff you can buy in a big amount like a gallon or so. I was told about GM Top End cleaner. Anyone use that stuff?
lol the advance near me actaully had 1 gal, 2.5gal and 5 gallow buckets of this stuff. Do you think i should remove the valve stem seals before soakin the head?
Purple Power is highly caustic. Wear gloves. You can get chemical burns.
lol yea the guy advance warned me about that too.
damn. looks brand new
Purple Power did that? Damn...! I gotta get me some of that!
if no access to purple power, what to use?
Heres some more pics
Inside the exhaust ports it left some kinda white build up but now that its dried out it comes off like powder?
and it kinda funked up the out side
Im gonna take a wire brush tomorrow to the outside before i paint the head. Hopfully that will take off the blackish gray stuff and that white crap.
yea i mean as soon as i pulled it out i washed it off with a hose. i made sure i got it all off and this still happend.
well now theres a major problem. The inside of the head is covered in a white powder that only comes off with a scrub pad or a wire brush.
well it did the same thing to my intake.
it kinda looks like to me its calcium on it. I guess im gonna take it to a shop and see if they can get it clean. If not i guess its time for a new head.
just soak the head in kerosene. thats what they use in a parts cleaner and it works pretty damn good.
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
