Does anyone have the instructions and what all do i need to buy. Couldnt get a straight awnser by searching. Thanks
13.1 @ 115
sUiCiDe,
I never had any issues with the swap I did above. Started up on the first turn of the key. Either way will work.
i think i may do the neon way cause my buddy has a older style neon that he can help me out with
13.1 @ 115
and you know what kind msd ignition box those it use.
both are relle easy, only difference are the number of wires u have to sodder and the output voltage. neon coils= 36,000 volts, gm coils= 45,000 volts per coil so a total of 90k. ive done both swaps an i prefer th gm coils. but both work great and if u want to save time and money, neon all the way.
"still want to smash that like the fist of an angry god"
i searched for the part number for the coils but i only came up with a 2 pin connector..  does anyone know if there is a different part number for the coils?
lafonjef wrote:i searched for the part number for the coils but i only came up with a 2 pin connector..  does anyone know if there is a different part number for the coils?
ok... sry i found it.  it should be MSD part #8224...   not 8824.  hope this helps others
could you use the wires from a 2.2l or just get the universal cut to length ones?
k sweet.., i gotta  start getting parts to do this..
how is the swap coming along? if anyone needs some help with this on the 2.4 regarding the 2.2 coil swap just pm me.
neojuice how did u make ur bracket for ur msd coilpacks i wanna do something similar i love the set up of ur coils they are nice
Finally got mine together. Coils from a 98 Cavalier, wires from GTP. Love it. Sorry for the poor pic. Camera phone.
Oh shut up Eric lol.
Still has the factory connector. Easy switch back.
yeah i did the coil swap on mine...used the parts listed in the MSD diagram. GM coils, taylor wires.. solved my misfire problems in boost, and the car starts up real quick too
engine bay is kind of busy.. but heres a pic
14.82 @ 97 mph
that is some messy wiring
JBO since July 30, 2001
Where are you all getting your wires from?
Would the stock length from a 2.2 work?
We make our own. Mine are from a GTP though because I didn't feel like making them. Not sure about the 2.2 wires
Do they make a 4cyl universal wire kit that i can cut to length?
