My questions are about the cam that Scrufdog used. (.423" lift @ valve; 272 duration both lobes;
110 degree lobe centerline; 52 degrees overlap)
What would the idle be like with that much duration and could that cam be used on a daily driven car?
Can a stock cam can be reground to those specs?
I'd like to know this too, so... BUMP!
Go beyond the "bolt-on".
i would say you would need to increase your idle speed significantly, and depends what you mean by DD.
yes it could run as a DD, but might be a little on the uncomfortable side.
