I am a bit confuse about the lsj/sc injectors. Do we (00+ ld9) need to change the clips if we want to add these injectors or not, they are droppings with the exception of modifying the rail. Other question is the siemens deka 60lbs injectors, would they fit ok in the stock injectors position without leaking and are they long enough? And if they do fit, do we need to change the injectors clips or not? Thanks in advance.
orlblackz wrote:I am a bit confuse about the lsj/sc injectors. Do we (00+ ld9) need to change the clips if we want to add these injectors or not, they are droppings with the exception of modifying the rail. Other question is the siemens deka 60lbs injectors, would they fit ok in the stock injectors position without leaking and are they long enough? And if they do fit, do we need to change the injectors clips or not? Thanks in advance.
The LSJ/SC injectors connect to the stock clips on 99+ 2.4's.
I just want to add that you can buy adapter clips on ebay to go between one style to another and it is plug in play no wire cutting or splicing.
Thanks, guys. How about the size of the deka injectors (height, holes) not cc. would it fit on the fuel rail?
