My 2000 LD9 is nearing completion, and we need one more gasket. It's the one where the timing chain housing connects to the block.
Here's a picture, taken from the head gasket set image from NAPA:
What is this gasket called and where can I buy it? I don't see it anywhere on NAPA's gaskets and seals section or any other section.
Any and all help is greatly appreciated!
2001 Olds Alero (LD9)
650 whp / 543 ft-lb
@turboalero
Do you still have your old one? I usualy reuse mine with a lite coat of RTV.
i could, this is a spare engine being built. my current one in the car has 190k though
it's just nice to get it all together as much as possible before the swap
650 whp / 543 ft-lb
@turboalero
If I could find one I would give it to you, hell you are only a few cities away from me.
yeah... i'm thinking it's probably a dealer only thing
650 whp / 543 ft-lb
@turboalero
You can get them from auto parts stores, I just never buy them there.
It's $55.71 shipped from GMPartsDirect, and that'll take a while. I need to find someplace local that has it. I'll have to go to a NAPA I guess and see if they have it.
Housing Gasket Set
P/N: 12360464
That's the GM part number; itd be nice if I could find a local store part number if there is such a thing, unless I just show up with that number and a description and hope they can find it for me.
650 whp / 543 ft-lb
@turboalero
Is it the same between 2.3 and 2.4? If so you would be in luck.
if you want to try autozone maybe try this part number: KWK99199.... it does show a pic so i cant confirm it for you but it is called timing cover seal and is $50.99.. but again look at it before you get it. hope that helps
-- MyZcar
dear god for that kinda money just buy a full fel-pro kit.
You look so much cuter with something in your mouth.
Im going to drop off a 2.3 gasket for him, hopefully it works.
Thanks again mitdr774! I'll be there around 5:00ish if you wanna BS a bit. lol
650 whp / 543 ft-lb
@turboalero
I believe its in the Felpro kits...... maybe the "conversion" kit? I have a few in my garage, I also believe the 2.3 and 2.4 are the same......
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
the 2.3 gasket matches up to the block. Looks like it will work.
Yep, will work. Swapping in the new engine next Monday.
Gracias.
650 whp / 543 ft-lb
@turboalero
Welcome, enjoy the fresh engine.
Now do a 2.3 oil pump swap.
