Me and my friend are making me an exhaust system and I need to know the size of the stock exhaust before we go and buy parts. I got a 97 2.2L cavalier. Thanks.
The stock exhaust is less than 2", right around 1-7/8"OD, but most people use a 2" ID or 2.25" ID exhaust on the 2.2L OHV. Bear in mind that the OHV motors do not respond to modifications well. You have to do major work to get the power you are looking for. I would be thinking boost or juice along with a forged bottom end rebuild.
use 2.25" piping.
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
stock size is 1 7/8" but yes use 2.25" piping.
what is a good place to have a stock cam reground? I would rather send it somewhere that has done it to these cars before, rather than having a local shop that doesn't know what they are doing try it.
Is the exhaust universal on all cavaliers 95 and up? I found a catback for a 97 and I dont know if the exhaust is the same on all cavaliers or not. Im assuming yes, but I still want a definite answer from someone who knows before cashing out.
Thanks for the correction...I forgot about head work, and cams, but was rather concerned with bolt ons alone. You will need to check to see if your 95 has OBD I or OBD II (yes, I recall a few 95s having OBD I and others with OBD II), and if the car is OBD II, you will not have a problem, however, with an OBD I car, you may need to find a way to plug the downstream O2 sensor hole in the piping, or just cut it off and seal the hole.
wow madjack you are a wealth of info i will remember that when i finaly get around to doing my 99 2200
Thank you for the help MadJack.
the last half of the cat back is about 2" before that its really small maybe 1.75 im guessing. why they didnt make the whole cat back 2" i dont know but its way too small. same goes for the downpipe. this is on my 2001 though.
Working on obtainting an M-Class license... ?? Hint: 2 wheels.
Toronto Cavalier wrote:the last half of the cat back is about 2" before that its really small maybe 1.75 im guessing. why they didnt make the whole cat back 2" i dont know but its way too small. same goes for the downpipe. this is on my 2001 though.
By god, SHUT UP.
The FULL exhaust 95-05 is ALL 1 7/8. had you of read the thread, you might have actually learned that. Not one pert of the exhaust is over the 1 7/8. only the tip side of it, and even then, it's not common. oh, and it's not "too small" for fuel economy and noise restrictions. it's actually the best size possible.
MadJack, don't be surprised if you get a PM from me in the new year. I'll prolly be going with Comp Cams and getting the 1.6 lifters as I noticed you had been talking about in your rocker lifter thread.
Don't get fixed on a set rocker ratio, till you decide on what cam profile you'll be going with. You may want to get a set of 1.5:1 rockers. It may sound like a step backwards, but it's not, if the cam has more lift with the 1.5 rockers than the stock spec 1.6 rockers have on the stock cam, let alone a faster ramp rate.
Edit: Make a plan for what you want and can do, then we can get a cam best suited for your application. All the other parts can match what you have. This will yield the best results.
Edited 1 time(s). Last edited Sunday, December 28, 2008 3:55 PM
